Originally Posted by alanisrox69
Fios is for whatever bizzarre reason re-encoding it to a higher bitrate. That's why, in your Matrix shots, the AE screenie of Keanu, his face looks pasty and "flat" looking, like Windows Media Videos....and in the Cable feed, it looks clear with what you say "grain" which is how it's SUPPOSED to look. In the Fios capture it's just getting 'flattened'..... I know it seems bizzarre as a re-encode to a higher bitrate should look transparent...but in this case it is not..........
Please note the first shot in the previous posting was not of the same frame. I noticed that this morning and added a note to disregard the first image.
The Comcast feed is clearly not as it is delivered, because there is blocking on the most intense scenes that is not present on the FiOS feed. I have not posted these images because they are not representative of most action on A&E, which still looks very good on Comcast. A&E has the highest bitrate of Comcast's new HD channels, and it's only a 720p channel, so you would expect it to remain quite good with motion.
As far as grain, the FiOS feed of A&E still has grain. It just has noticeably less grain. FiOS could be applying some sort of filter to reduce grain, Comcast could be applying some form of edge enhancement, or it could be a combination of the two. I assumed that Comcast was responsible because the grain was clearly visible on the A&E logo, but I suppose the grain could just be showing through from behind.
