AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Help With NEC LT260
Help With NEC LT260
post #1 of 5
I have a NEC LT260 and when I connect an input it goes to a black screen as if the picture is there, but it remains black, when i start it up with no input it goes to the Blue screen, but when i plug something in it goes to the black screen, I have tried to put it back to Factory Defaults but it still doesn't work. Any advise?
post #2 of 5
on this 4x3 pj, what r u using for a source(s)?
cables?
pj resolution settings?
source resolution settings?
folks need data/info to help!
post #3 of 5
I'm trying to get the VGA's to work but i have tried all of them, I've used the supplied vga cable, along with my VGA Cable for my Xbox, I'm not sure if u can set the resolution from the projector, my Input is 1024x768 (I Think that is what it is for both my computer and Xbox, i have tried it on 800x600 also) also i forgot to mention that the inputs on the Component and S-Video don't go to the black screen as i mentioned, it says there is no signal as if nothing was plugged in. Sorry for not including this info.
post #4 of 5
i dont know anything about xbox or connecting computers up to pjs.
try hooking up a dvd player w composite/s video and see if that works.
otherwise have to wait for someone else to jump in.
sorry i couldnt help more.
good luck!
post #5 of 5
its not that big of deal, i was sitting around the house messing with a Christie LW300 my dad brought home for a meeting and I was wondering this one could be fixed, I might just part it out on eBay since the lamp is brand new.
