I'm not sure if I have the 42PF7220A or 42PF7320A and taking it off the wall just to check the back of the TV is a bit of a hassel.
Anyway, I purchased the TV from CC in Feb 2006 for about $2000. I am running the latest firmware updates, but in the last month or so, the top half of the screen will go black after the TV has been on for a little while. It occurs regardless of what I'm doing (playing Wii, watching TV using the HD cable box, or playing a DVD). It seems to be getting worse and worse.
From searching some of the threads I found a few other people who have experienced the same issue. So, I'm wondering:
who else is having this problem?
what was the problem that had to be fixed?
how much did it cost? (mine is of course out of warranty)
