Well, it's not a smart antenna (which is the subject of this thread)....
post #121 of 167
6/1/09 at 6:56pm
) design is if you add the idea above (limited to 16) with the idea of using the RF channel number (per CEA-542-B) and polarization to control a Antenna box additionally with any number of F-ports for every 6Mhz channel (one for each polarity) in the acceptable range. You have an antenna controller inside the box that constantly measures it's own antennas for each frequency to find the best antenna to assign to each channel and polarity (this does take a bit of control AWAY from the STB) and then the STB asks for that RF channel and polarity the Antenna controller selects the one it thinks is the best to recieve that spcefic RF channel & polarity. This gives you an virtually unlimited number of antennas that does not care if you or the antennas move because it constantly updates its own opinion of which channel is best (not the STB deciding which Virtual Antenna is best) and gives it to you.
! The discontinued external and internal Smart antennas appeared to be good as far as the "Light Green" zone. However, it seems that with the aid of trees 30ft or more tall (for reflections I suppose), I'm located in a "Blue" to "Purple" zone -- and even then I can't expect to pick up Baltimore, only Philadelphia (~35mi)
. So, I'm not sure if playing with one of those two Smart antennas would have done me any good -- even with the external placed as high as I reasonably could. Sometimes, living in a hole is really annoying
