Originally Posted by
aaronwt
When I downloaded the firmware I chose the one that said for VISTA and it was 402F.
The 402F Firmware is the older April firmware. You want the June firmware (080620 - 06/24/08).
Ignore what Windows version is listed (2000, XP, Vista), it means absolutely nothing. The file you download works on any Computer (PC or Mac), as long as it has a USB Port or CD/DVD Drive.
muzz
I don't know why they do the Vista/XP thing at all.
They're trying to help users who assume it matters but in reality they just confuse people.
muzz
0402 looks like the April Firmware.
0620 is the June firmware.
Correct. 0620 translates to June 20th, 0402 translates to April 2nd.
muzz
I'm pretty sure I've seen Vista folks DL the 0620 FW(under ALL, or 2000/XP) and copy it to a USB drive without issue.
Correct. The Windows versions mean ABSOLUTELY NOTHING. It won't matter if you use Windows, Linux or MAC OS.
It wouldn't matter if you used an Amiga, as long as it has a CD/DVD Drive. The CD/DVD format is universal on all computers since time began
(well pretty much).
aaronwt
I see the 620 now. I didn't even look at that since it didn't say anything about the US.
Again that's just to confuse people. Why the April firmware says "US, Canada Only" is anyone's guess, they've not added that for any other firmware (so why add it for the April firmware???). Again it's rubbish.
All BH200 firmware works with any BH200 bought world-wide. This has been confirmed many times by users.
Download the June (0620) firmware. It's virtually identical to the April firmware but you may as well upgrade to the latest one.
