Originally Posted by
willis1975
could someone tell me what one this is and if i put this on instead june what would i loose on my bh200?
thanks
They're 99% identical. You can see what June adds in the first post. Some have said that BD-R and BD-RE support is removed with the June firmware.
It was never official to be fair:
http://en.wikipedia.org/wiki/Blu-ray_Disc_recordable
As far as I know that's the only thing June removes over April.
willis1975
also would i damage my player going back to april firmware when already updated to junes????
Generally speaking there is always a risk when upgrading/downgrading firmware (e.g - if power is lost for example) but other than that you can upgrade or downgrade firmware as much as you like. It won't do any harm. When you install firmware it overwrites the existing one.
The April firmware can be downloaded from the various LG Service sites (see the link in the first post). The April 2008 firmware is the second one down from the top, saying:
[US, Canada Only] Software Update for BH200
Despite saying that it works with all BH200s (certainly from Europe too anyway). The top one is June 2008, the third January 2008 and bottom/fourth November 2007.
