It depends what firmware you have installed, in relation to what can be updated over Ethernet:
* March Firmware will upgrade both the driver to 0702 and firmware to the April firmware. The April firmware will do the same but obviously you already have the latest firmware. I don't think "anyone" has actually been able to upgrade March to April firmware over ethernet though, it may come later.
* November and January firmware will only upgrade the driver to 0702.
Both firmware and driver upgrades can be done manually, meaning you can ignore the ethernet upgrade if you wish.
Originally Posted by
pobff
Most likely, it'll have the 701 firmware and u'll have to update it to 702 before the network is enabled for firmware update through network?
Incorrect
. The respective
change logs say:
* April Firmware:
Firmware update via Network has been enabled - Driver update was already there
* 0702 Driver: Fixes issues with Saw IV, Hitman and Enchanted on Blu-ray
As I understand it that's all the 0702 driver adds over the 0701 driver. I asked the LG Engineer what prior driver upgrades brought but they didn't know. The March firmware Change Log is identical to the April firmware (it's now official).
I'm not sure if it's the firmware or the driver that enables network updates.
It's the firmware.
The driver is an upgrade for the physical drive itself (where you put the disc). It doesn't control the rest of the Player.
dransquo
If I connect this new bh200 to internet and update the firmware, does it work or do I need to make a firmware update using CD/USB to enable ethernet updates?
When you get your BH200 check what firmware/driver is installed (instructions in the Mini-FAQ), and if they're older than the April firmware I'd first install that, then either:
1. Check for updates to bring in the 0702 driver
2. Then install the 0702 driver manually
It's likely your BH200 will have the November or January firmware preloaded. It could have the April firmware but I'd be surprised, considering the March firmware is Beta it won't have that.
Personally I plan to upgrade both by CD-RW or USB Stick but that's just my personal preference. I already have the files so it's just simpler to install them manually.
dransquo
if the update using ethernet works just opened, does it update to the 2008-04-02 firmware??
Yes if it happens to have the March firmware preloaded but that's very unlikely so in reality no.
