AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Reciever for home Theater
post #1 of 2
I've been reading and learning, but I'm not too tech savvy!
I have a new 1080P Samgsung 58" Plasma
HD Cox Cable digital box
Ps3 for BluRay
and a surround soud system
I have HDMI 1.3 cable run and just need a reciever.
I'm wanting the best picture quality possible using a Ps3 for movies. My budget is around $600+-
Is there a reviecer that has HDMI and 1080p that doesn't have any lip sinking problems or require any software updates? Basically a plug & play for a novice?
Thanks Guys!
post #2 of 2
That price range I would recommend the Onkyo 605. It has 1080P pass through but will up convert analog channels to 720P. You won't get into the 1080P up conversion until you get to the Onkyo 875 which is about $1500 I believe.
