AVS › AVS Forum › Display Devices › Rear Projection Units › Panasonic LCD Projection with Partial Yellow Tint on Screen
post #1 of 9
I've had this PT50LC14 LCD Projection TV for 4 years. No problems except for having to change the bulb about 6 months ago. Now more and more, there is a yellow tint appearing across about 60-70% of the screen. I called a local TV repair shop and they said they never heard of of such a thing? Could it be caused by the bulb? It's 4 years old, and the idea of paying someone to start swapping out parts to try to find the problem is troubling. Any ideas are appreicated. Thanks!
post #2 of 9
I also have several yellow blobs on my TV (PT-50LC14). It is due to a burnt polarizer filter just past the blue filter for the blue chip. This TV is a three chip design with red, blue and green chips.
I am currently trying to get a new polarizer filter from Panasonic.
Duane at duanetr@sbcglobal.net
Update: Panasonic was of no help, other than I could buy a new light engine from a Authorized dealer. I am now trying to buy a polarized blue unit from partstore.com.
post #3 of 9
Update: I received a new blue polarizer unit from Panasonic. I installed it
and it fixed my problem!!!!
post #4 of 9
I have the same yellow tint on part of the screen on my Panasonic PT50LC14 and would like to replace the blue polarizer filter . Can anyone tell me where this is located and how to access it for replacement . Thanks for any response.
post #5 of 9
Gps_man2,
E-Mail me and will help you!
Duane duanetr@sbcglobal.net
post #6 of 9
Hey guys my display Sony KDF- E50A10 also has a round yellow tint in the center. Could be that my light engine is bad?
I also posted this in the A10 master thread but no help.
post #7 of 9
Do you have the part number for the filter to get rid of the yellow tint on a Panasonic tv ?
post #8 of 9
Every Panasonic model number tv will have a different part number for the blue input polarizing filter.
post #9 of 9
  Back to Forum: Rear Projection Units
