Originally Posted by
hlomax
Jet,
Job well done...
Looks good.. couple of questions?
1. how bright are the lights?
2. is it in you theater or a seperate room?..
Max
Thanks Max.
The lighting in the candy area is rope lighting. Bright enough to light up the candy, but not extremely bright, but I would turn off during a movie. I have them plugged into a surge protector that I can turn on/off with a switch.
This is in the theater. I have a bump out area in the theater ( to the left of the screen if you are looking at the screen) that this sits perfectly in.
did you design this? I saw a reference in the thread to "HTB plans" (no idea what that means) but are these available to the general public or for purchase?
This was built from a hybrid of plans I have seen. If you look earlier in this thread, there are a couple plans posted. I will eventually post the plans when I write them up.
