AVS › AVS Forum › Display Devices › Rear Projection Units › RPCRT Reference Material - Color Decoding
RPCRT Reference Material - Color Decoding - Page 37
post #1081 of 1087
post #1082 of 1087
Truly awesome, Leo!
b
post #1083 of 1087
I came across a "Sunset" setting on my Kodak EasyShare. I know I swore I'd never do this again but, after seeing yours, I had to give it another try. From the first disc:
Not sure anyone else stops by here anymore, but, if you do, let me know.
Michael
post #1084 of 1087
Wow! Those are first rate and truly cool, Michael. It think you've got your groove back!
b
post #1085 of 1087
Thanks, Bob. Honestly, I don't think I ever had the "groove," but this setting comes closer than anything else I've tried. Too bad the camera doesn't have any manual options.
post #1086 of 1087
Nice shooting Michael!!!
I have to agree with Bob... you had some very good screen shots in the past.
Just keep on shooting... I think that setting works.
post #1087 of 1087
Your shots are way more focused than my camera's, on auto. My camera's auto setting gives me totally unfocused pictures, as it seems to get confused by the view screen not actually being the CRT screen, and the CRT screen being what is actually producing the picture. I have to very carefully manually focus mine, and it is really tedious because there is no numbering system for a starting point on each focusing run. Once you get it close, you don't get to know exactly what number that is, so you can go forward or back 2 steps to get it better. You have to go back and forth simply by pushing the button very carefully and abruptly, and counting clicks.
I envy yours!
b
  Back to Forum: Rear Projection Units
