AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Help Programming Comcast Custom DVR 3 Remote for a Vizio VS42LF
post #1 of 3
We have a comcast HD DVR box with their remote hook up to our new Vizio VS42LF TV. We hooked up the TV about a month ago and it worked fine, then about 3 days ago, we found that we were no longer able to adjust the volume or turn off the TV with the comcast remote. We called Comcast, they said that our remote had gone bad so we stopped by their location and replaced it with another one. We reprogrammed it, it worked for a few hours, then it stopped again. We called Comcast back, and repeated the process over again. I can't imagine that we're the only people with this problem. The code that we use that came with the Comcast remote that seemed to work each time we swap out the remote is 11758. Do you know if there is another code that we could use? The other 3 codes, 10864, 10885, and 11756 that was listed on the comcast remote instruction did not work for us.
If we can't get the Comcast remote to work, is there a universal remote that you know will work that we need to buy?
post #2 of 3
I doubt that 3 remotes suddenly went belly up on you, its probably IR interference perhaps from the Tv itself. Other codes to try 10178 & 10056.
post #3 of 3
If it's from IR interference from the TV, is there anything that I can do? We have the TV mounted on the wall and the cable box is sitting on the dresser drawer below and in front of the TV (if that makes sense).
  Back to Forum: Remote Control Area
