Ok, by no means am I an audiophile, and I'm wiring up my first "high end" home theater system while finishing a basement... A friend gave me a spool of 12 AWG wire that he got somewhere on his job... I know it's not "speaker wire" but it is 12 gauge copper wire shielded, but I think it's used for wiring electric appliances and things of that nature... I don't know if the colors mean anything, but it's green with a thin yellow stripe winding around it. The wire is marked:
"12 AWG Type MIW or THHN or THWN or Gas and Oil Res 11 600v (something) or AWM VW .l... AlW.K ... C-UL Type T-90 Nylon or TWN 75FTI"
This is absolutely greek to me... My question is can I use this wire as speaker wire? Pro's Con's, etc. I have dumped some money into my components, so I don't want to sacrifice performance because of my wires, but if it will give me good results, I'd like to use it, at least for the shorter runs (Front L/R, center). I appreciate it! I'm fairly certain I CAN use the speaker wire, I'm just wondering what kind of perfomance I'll get out of it... bottom line is I've got about 300 feet of it for nothing.
Mike
Mike
Basically, if it is flexible enough for you to use, and you can twist the ends to make your connections, your probably good to go. The main thing is you select the proper gauge for the distance and speakers your using.
