AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › Painting blackout cloth
post #1 of 3
I'm expecting my HC1500 today and am pretty excited to say the least. I have already built a DIY screen using blackout cloth from Joann's stretched across a wood frame. Because I will have some ambient light I am considering painting the blackout cloth to a grey tint.
I've been reading some of the painting threads but have hit information overload point
Little confused on the right tint, knowing that it is not a perfect science and every room is different... I am considering Glidden EverMore Premium Exterior Flat but between the below tints I really dont know which I should try...any advice would be greatly appreciated.
thanks!
* 00NN 45/000 ??? . . . "Dover Grey"
* 00NN 53/000 W/B . . "Veil" (~N7.5)
* 00NN 62/000 W/B . . "Universal Gray" (~N8)
* 00NN 72/000 W/B . . "Snow Field" (~N8.5)
post #2 of 3
Hey,
I have a mits 1500 and I just painted a artists canvas with the Black Widow mix. I used 4 parts PPG speedhide bermuda beige mixed with one part creatix auto air aluminum (fine) from blick.com (also where I got the artists canvas).
Rolled 2 coats of it on over two coats of Kilz2 primer. It looks Awesome! Great dark blacks, and whites and colors are plenty bright even in low lamp mode.
post #3 of 3
thanks!
Given your projector and some ambient light I would go with 00NN 62/000 W/B . . "Universal Gray" (~N8).
  Back to Forum: DIY Screen Section
