Originally Posted by perritterd
Hi Bill. I took your advice and, basically, started over with the defaults and worked my fwd. with the greyscale settings w/ the Energy Saver turned "OFF". I then attempted to set my color space following the link you gave me. One issue I have when adj. the color space, I am trying to keep the dE as low as possible when adj. the x/y. This doesn't necessarily allow for the Pri. pts. to line up on the black triangle-Why not? It would seem that the closer you set your Pri. color the the black triangle, you should get a better dE value-that doesn't seem to be the case. You have given me a lot of things to think about above, but I don't think I am ready to do a whole lot of experimenting just yet-atleast, not until I can get the greyscale/color, & Y to get reasonably correct. I included a couple of after calibration readings from a clean start. If you get a chance, please let me know what you think. As you will see, even following your link's tutorial advice, I still only get a contrast ration of around 900.
Thanks for your help Bill.
Bob.
Bob.
As before, your RGB levels look remarkably smooth. All the Samsung LCDs have a variation somewhere at the low end. Mine has a blue hump around 25%, some have a blue hump around 40%, yours seems to have a hump around 20%. You are taking the same approach I have, to try to minimize the error in the middle and high ends, as any remaining color error seems less visible at the low end.
So, you have a more normal level of gamma, probably a little low as if you want to go back to a gamma value of -1 or -2. Since your gamma dropped so much, I infer that the high gamma before as an artifact of Energy Saving being set to Auto. As it stands, the picture should look a little flat, as if there is not enough depth of field. In your case, I would start moving the gamma to -1. Pushing it higher than that might make the gamma too high at the low end and crush blacks too much. (But see the Spyder remarks below.)
Later you can try a trick I described here that worked for me to create a lump such that the gamma at the low end turns back downward, but it has not worked for everyone. When playing with the gamma at the low end, I used the 5% grayscale measures and then the Near Black HCFR test and AVSHD pattern to measure from 0%, 1%, ..., 9%, 10% levels. On the Near Black test, if you right click on the graphical display and change to log format, the resulting numbers are gamma values.
I just looked back and noticed that you wrote you had a Spyder2. Most people I've seen have used the EyeOne to calibrate the A650. In fact, I see only one other person in this thread having ever mentioned a Spyder. So it could be that the lower contrast ratio you are measuring is just a difference in the probe, and not an issue with the set at all. If the Spyder2 doesn't measure down to 0.1fL cd/m2, it's going to be hard to compare your results with anyone else's. You may have to check for any black crush with the continuous Pluge patterns or by watching films with lots of near black content. And if this is indeed an effect of the probe, you may be able to push the gamma control to -2 and not actually lose black detail.
You did not mention what your source device was, a bluray player or a PC. Lots of complicated things can happen with a PC source; it is simpler to start with a bluray player or a PS3.
Color: here's the shorter version. Using Tom Huffman's terminology, that saturation is the distance from the white point and hue is the angle, the older CIE76 measure weighted hue and saturation error equally. So, using it, one tends to choose compromises that are on the black reference triangle. Essentially it tells you to choose the more intense color, even if it is the wrong color. CIE94 and CIE2000 are based on more and later studies of how people perceive color differences, and they emphasize hue error over saturation error. Essentially, it is more important to get the right color, even if it is less intense. So if you minimize the error using these formulas, you will tend to choose a color in line between white and the reference primary. Obviously there is a weighting process in the formula, not that one takes complete precedence over the other.
In your case, if you add more Red to the Green primary, moving your green to be near to or on the line between white and the Rec709 green, you may find that you see a lower dE measure using CIE94 or CIE2000. CIE2000 added some special treatment around red and blue, so it is hard to predict the tradeoff between hue and saturation.
As I mentioned above, Kaki did not take my word for it. But after doing some research on his own, he found enough authoritative sources to adopt CIE94. I believe it is currently the default choice with the Calman software.
Another thing to notice is that, between the standards, they changed the criteria for a minimal perceivable difference. In Tom Huffman's spreadsheet at the bottom of this Guide comparing dE calculations, he indicates that for CIELAB76, the minimum perceptible difference is 2.0 and minimal acceptable difference is 4.0, whereas with CIE94 he gives the minimum perceptible as 1.0 and minimum acceptable as 1.5 Obviously "acceptable" for us is limited to the best we can achieve with the Samsung panels.
If you are really interested and want to see the formulas, they are available on Bruce Lindbloom's site. Y enters into the calculation differently in the newer formulas, which is why the spreadsheet gives different recommendations when CIE94 or CIE2000 is chosen.
As far as the numbers in your file, it looks as if you are using the CIE76 measure, and your Y values are very close to accurate. So the picture should be looking pretty good; perhaps the green is a little dark in color, judging by the CIE94 measure, but maybe not enough to notice.
Hope this helps,
Bill
P.S. I just looked back at the experiments I made comparing a Spyder3 to an EyeOne LT. The Spyder3 reported higher light levels, at the bottom and high end, giving an overall contrast of 963:1 compared to 1446:1 for the EyeOne. This without changing any setting on the Samsung. So I think your concern about the contrast ratio being low is misplaced, it's the probe and not the calibration that is giving you different results. (By the way, I abandoned the Spyder3 after trying it because the color triangle was twisted, a problem you don't seem to be having with the Spyder2.)
