AVS › AVS Forum › Blu-ray & HD DVD › Dual Format Players › LG BH200: Hidden Hacking Options
LG BH200: Hidden Hacking Options - Page 8
post #211 of 332
I'm not the best person to be answering this but I think it's Crutchfield or eBay.
post #212 of 332
Count out Crutchfield. They are now showing it as discontinued and have no more for sale. I'd say either eBay or Amazon.com.
post #213 of 332
Fry's in Austin may or may not still have the two hidden on the floor with all the DVD players. They probably still want $599 though.
post #214 of 332
Best Buys still have them, but also at $599 (though I heard they will be on sale). Ebay looks like it's gone up in price since I last looked. And the people trying to charge extra because they made it "region free" are hillarious.
post #215 of 332
No way, any examples? You can just post the item number.
That's really cheeky considering they did no work of their own. You'd think they'd give credit to those who did (us) .
post #216 of 332
350064887076
I assume that's why they are trying to charge $599 when they aren't going for anywhere near that
post #217 of 332
I love where they say:
It will be Blu-Ray Profile 2.0
And where he says he can provide an upgrade CD, why doesn't he upgrade it for buyers?
Talk about taking all the credit for:
  • For Blu-Ray = Region A (You can change between A, B, or C easily)
  • For Regular DVD = Region 1 or 0 (You can change to Region 0 easily)
I've no problem with the information being passed around (the more people know the better) but give credit where it's due, something I've made a point of doing in the Mini-FAQ etc . . .
Speaking personally I didn't spend all the time I have on this so others can steal it without giving any credit where it's due. I've sent him a message telling him so.
post #218 of 332
I'm from the Land down Under and now im thinking about buying this LG BH200 overseas for both my HD-DVD Collection (3/4 of my HD-DVD Collection is Dolby TrueHD and Blu-Ray (i have started my collection already), also since it also has the BD Region Hack, do u think its not a waste to get this BH200?
Also im getting the Yamaha 1800, coupled with this plus this Player, could you not go wrong?
P.S i dont mind spending the money for this player if it's return rate has been very low as im from OZ and i do know LG is very Hit or Miss when it comes to Repairs and since the voltage is different, what do i need to change the voltage from 240V to 220v?
Cause im THIS close to buy it, cause i got the HDEP10 and to change it to this would b fantastic!!!
post #219 of 332
I think if you want one you should go for it. Can you not buy them locally? I guess not.
They're by far the cheapest in North America but of course they're then 100v (or whatever it is exactly) instead of 220v. I thought Australia used the same voltage as Europe? I've used my UK "only" electric toothbrush in Australia fine (I'm pretty sure).
So presuming I'm right there you could import one from Europe, Belgium looks to be the cheapest. I got mine from a Belgium company:
http://www.avforums.com/forums/showthread.php?t=754125
I don't know if they ship to Australia though. If you do need a voltage converter they're readily available on eBay etc...
post #220 of 332
bought one on ebay it's on his way now
http://www.gadgetell.com/tech/commen...player-lineup/
post #221 of 332
Thanks for the link. That's from the original Korean article in the "BH300" thread.
post #222 of 332
Interestingly AlfaGT has just told me his European Swiss BH200 code is:
43 48 00 96 00 05 00 40
43 48 is CH which is the country code for Switzerland, so that makes sense but 96 is a new value. The user who reported that 82 was his value owned a UK BH100. His value was:
44 45 00 82 00 05 00 40
44 45 is DE so clearly his UK model was sourced from Germany but clearly there are also localised European BH200s too. AlfaGT's European BH200 is for the Swiss market only.
So either:
1. The German BH100 is 82 and the Swiss BH200 is 96
2. 82 is the European code for all the BH100s and 92 for the BH200s
We need to someone to check another European BH200.
p.s - Does someone (owning a USA/Canadian BH200) fancy trying 96 to see if the BD Region value changes?
I'm a confused... got my US BH200 today and changed the 4th bit to 96 and set the DVD-Region to 0. Now my player also shows 43 48 00 96 00 05 00 40 (previously it was 55 53 00 00 00 05 00 40), but he also sets the DVD-Region back to 2...
Anyone has an idea what is happening here?
Mike
post #223 of 332
I'm not sure it does any harm but you didn't need to change the country too (55 53 to 43 48), personally I'd put that back.
Contrary to what the Region Info menu says, as you've run the RMTM CD can you still play R1 DVDs? The RMTM CD overwrites whatever it set in the EEPROM menu as far as SD DVD Region Coding.
To be honest you'd be better using the instructions, here:
http://www.avsforum.com/avs-vb/showthread.php?t=1009104
Follow the SD DVD Region Free and BD Region instructions, all should then be fine. It doesn't matter if you do the SD DVD or BD instructions first. The comments in the post you've quoted aren't really meant to be followed "as instructions". I hope that helps .
post #224 of 332
Contrary to what the Region Info menu says, as you've run the RMTM CD can you still play R1 DVDs? The RMTM CD overwrites whatever it set in the EEPROM menu as far as SD DVD Region Coding. To be honest you'd be better of using the instructions in here:
I hope that helps .
Well, I didn't change the country, in fact I have no idea how that got changed (it now also shows 'CH' under 'area' in the 'Lock' menu). And no, I couldn't play a R1 DVD...
Going by those instructions, you say I should use 92 instad of 96 for B2 PAL?
*** START EDIT ***
I might have found what happened with the DVD-Region setting:
"As you have noted, changing EEPROM byte 4 doesn't override the DVD Region setting made by the RMTM CD. However, I found that if you perform a Factory Reset by pressing PAUSE on the System Information screen, the DVD Region code does get changed to what you would expect, i.e., 8D -> R1, 96 -> R2."
I think I pressed PAUSE to get out of this menu. What should I press instead to get out of it?
*** END EDIT ***
Mike
post #225 of 332
Press "Home" to exit the System Info screen (without performing a Factory Reset).
post #226 of 332
It doesn't make any difference, both are identical. If memory serves me correctly 92 is the default code for a Belgium sourced Player and 96 Switzerland but they're actually identical.
There are unique codes for each country but many give the exact same results. 92 is easier to switch between 80 and back again, that's the only reason I choice it, over 96 for the instructions. Use whichever you prefer.
Ah yes that would've been it. Pressing "Pause" in that menu takes the RMTM hack with it, when restoring to Factory defaults.
To explain: The fourth HEX value contains: SD DVD Region Info, BD Region Info and PAL Support but the RMTM Hack overrides the SD DVD Region Info. When you wipe that it reverts back to whatever Region is stored in the fourth HEX value (i.e - Switzerland = SD DVD Region 2 ONLY).
No harm done though!
Presumably you had a valid reason to switch it to: "PAL Enabled + BD Region B" so just re-run the RMTM Hack, choose R0 again and job done!
Then just switch between BD Region A or BD Region B as needed. Personally I wouldn't switch between "BD" regions too often, just in case but in theory there should be no harm doing this. I plan to leave mine on Region A and just switch it while watching Region B discs.
Oilblue has answered your main question. I hope that helps.
post #227 of 332
thanks, gonna use this in the future
many thanks to bradavon as well.
post #228 of 332
I've experienced to use the Internet update with my 2 French LG BH200.
I don't know why but with my original string (46 52 00 91 00 05 00 40) It was impossible to get from "other" in the home menu the Internet update functionality. I just changed my original string to 45 52 00 00 05 00 40 and this menu appears. Then a new version of a part of the software was ready to download. the name was "702" or something like that.
Any body knows what news exactly brings this update?
After have applied the RMTM Free zone patch and installed the 402F Bios update I still have on my 2 BH200 randomly drop during playing the movie BDR or HDDVD. This is not often, it's arriving once or twice mainly in the beginning of the movie.
Another thing, I've a chance here in France to have the complete collection of "The gendarme" with louis de Funes for who knows, these are very famous French movies made during the seventies. On My Thoshiba X-E1 all the HDDVD are working fine but all of them cannot run on the BH200. I'm obliged to tun off the player and then eject the HDDVD media because the BH200 goes into an erratic mode until complete crash. Is there anybody who got the same experience with other HDDVD or BDR?
Last one: My BH200 are not able to read combo SACD; that mean the CD special layer of a SACD which can be read on every regular CD player to keep compatibility with existing CD player base. Any experience also?
post #229 of 332
Something I've noticed here in France may be interesting for some of you: the majority of the BDR we can buy here are Not Region coded. The only one I've seen is "Die hard 4".
Its why I'm running my BH200 only in Region A because I use to buy My BDR through Internet from north America companies and my French DBR are not Region coded...
post #230 of 332
Do you mean, you changed it to? -
45 52 00 00 00 05 00 40
If so, that is why. 00 is the default American code (BD RA/No PAL support) and has Network Update available. The only codes with Network Update active are the North American codes (not any RB or RC codes and no other RA codes).
Driver 0702 brings: * Fixes issues with Saw IV, Hitman and Enchanted on Blu-ray.
I asked an LG Engineer (I'm pretty sure 3rd line) and that's what they told me.
Do you mean Les Gendarmes de Saint-Tropez on French HD-DVD? Another user has mentioned problems with that on the BH200. See the "Problem Discs" list here:
http://www.avsforum.com/avs-vb/showthread.php?t=1002769
You're right .
I've just tried "Genesis: We Can't Dance" Hybrid SACD and the BH200 recognises it as a DATA Disc. It then obviously doesn't know what to do with it.
I too have never come across a DVD or CD Player that isn't able to pick up the Redbook Audio CD Layer before. This is annoying as I have a few Hybrid SACDs I was planning to continue to use on my BH200.
Thanks for letting us know.
Are there any French only labels that use BD Region B (such as TF1 Video)? Fox of course distribute worldwide so their releases end up everywhere anyway.
post #231 of 332
Thanks for telling that the discs from "Les gendarmes" boxset doesn't work well on bh-200 on my HD-A1 they work ok but after the M6 logo the player needs about 1 minute to go to the warning screen.
post #232 of 332
Does this machine decode dts MA better than the Panasonic BDP10A, or would it be the same (through analog outputs).
post #233 of 332
The LG BH200 doesn't have Analogue outputs.
Can we use this thread for Hacking discussion please and use the Mini-FAQ or Owners threads for general discussion. Thanks.
post #234 of 332
hi i have a usa LGBH200 player and did the hack and changed the 4th hex to 80 and it worked. i can now play standard dvds from other regions on it and it plays perfectly on the player. im just surprised my tv displays the picture. one question though if i ever do another update from LG do i need to set the 80 back to 00 or it wont make a difference ? and also does the 80 make the player pal compatible or does it make pal as its default picture format for standard dvds ? what im asking is if i play a region 1 dvd and leave the hex on 80 will it be in pal or ntsc ?
post #235 of 332
You need to run the SD DVD Region Free hack to make it Region Free. If a PAL SD DVD worked you must've used a Region Free PAL DVD (or you'd already run the SD DVD Region Free hack). See here:
No you don't need to alter the EEPROM value before upgrading the firmware, or afterwards either. Feel free to leave it on 80. I've left mine on 80 (even though it's a Euro model). Firmware or Driver upgrades don't touch it.
Value 80 makes the player support NTSC or PAL, so NTSC DVDs output as NTSC and PAL DVDs as PAL. Before, the player only supported NTSC DVDs so PAL DVDs you'd get an error.
It outputs at whatever format the disc is encoded with. As Region 1 DVDs are always NTSC then they'll continue to output as NTSC. None of the hacks allow the LG BH200 to convert PAL to NTSC or NTSC to PAL, they output in whatever format the disc is encoded with.
The Mini-FAQ (link I post above) is the best one to read. I hope that helps.
post #236 of 332
i did the SD dvd region hack already or else i wouldnt be able to play those discs and i know those pal dvds arent region free cause ive tried them a 100 times before but now it works. it just flips me out that the picture displays on my tv. the funny thing is i have to leave resolution on auto now since i changed the hex to 80 because if i put it at 1080P or any other resolution the screen goes all blurry. the funny thing to when i played a region 1 standard dvd after i did the hack and the rest of the stuff the picture doesnt look as clear as it did before when it was 00
post #237 of 332
It's great to have little surprises like this, isn't it . Not all TVs in North America support PAL, you're lucky.
And when you set it to Auto it still definitely displays a 1080p image? If so I'm not sure why it's doing that. When you set it to 80, the initial load screen (when it's turning on) outputs at 50Hz (PAL) when before it would output at 60Hz (NTSC). I think once loaded it reverts to 60Hz.
Forum members Dring, Peterjcat or Krobar now more than I do about the technical side of the EEPROM Hack, they were the guys who worked it all out. You could PM one of them, Peterjcat maybe.
The funny thing to when i played a region 1 standard dvd after i did the hack and the rest of the stuff the picture doesnt look as clear as it did before when it was 00
What about NTSC DVDs, do they look any different? It could be that your TV doesn't quite like PAL 100%.
post #238 of 332
the NTSC DVDs dont look as sharp as before. and even though maybe the tv doesnt support pal 100% you said earlier that if i play a ntsc dvd should display a NTSC image and if i play a pal dvd should be a pal image on screen. i dont see any difference in the picture when i put in blu ray or HD dvd so they are fine. i just think il switch the hex back to 00 for now and when ever i need to play another region disc il just switch it to 80 again. i dont have that many different region discs anyways. and no when i put the resolution to auto doesnt look like 1080P anymore i can tell theres something missing. but doesnt pal support 1080P ? thats what i dont get that it wont let me put the resolution setting to 1080P or any other option. will only display on my screen if i do auto
post #239 of 332
Correct.
Good idea. You'll then be able to confirm it does in fact look sharper again.
Correct. PAL and NTSC are SD standards. The fourth hex value (00/80) controls more than just PAL/NTSC. It also for example chooses the Blu-ray region, off the top of my head 92 or 96 make it BD Region B, with PAL still enabled.
Ask Peterjcat or Dring if you want more information.
post #240 of 332
yah i switched it back to 00 and the region 1 movies display much sharper.
but thanks for the info youve been alot of help
  Back to Forum: Dual Format Players
