would I need to have a region B BD to try it out?
post #31 of 331
5/6/08 at 2:09pm
. There appeared a pop-up when playing the disc: "This FOX Blu-ray disc is ......blablabla (I don't remember)". I didn't check the region info window, but I tried Region B Blu-rays and Code 1 and 2 DVD's
. That's how that Dutch company does it, you do it on the remote.
) the thread over at AVForums.com (UK equivalent) would be dead.
brought up a screen with three choices:PAUSE, 2, 4, 8, 6, 5
Entering 3 displayed the EDID info received from the display via HDMI, which might be useful, e.g., for determining if your display claims to support 50 Hz or 24 Hz resolutions.1. System Log, 2. ATAPI Log, 3. HDMI EDID
When I change EEPROM byte 4 to 8D, three of the above lines change value:MODEL: SMB_PLAYER_CANADA
Country: CA
Option Code: 43 41 00 01 00 05 00 40
Initial Language: English
TVSystem: NTSC
BDRE: Enabled
BD: Enabled
BD9: Enabled
HDDVD: Enabled
3xDVD: Enabled
Screen Saver: 5
Show Mode: OFF
Admin Mode: OFF
Auto Power Off: ON
(That's probably just a print formatting or conversion bug in the 4th byte of the Option Code, treating it as a signed byte, converted to a 32-bit hex value.)MODEL: Non name model
Option Code: 43 41 00 FFFFFF8D 00 05 00 40
TVSystem: PAL
