AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Finally! Firsthand demo of Smyth "SVS Realiser"
Finally! Firsthand demo of Smyth "SVS Realiser" - Page 2
post #31 of 35
Originally Posted by DSperber View Post
There is an A/D conversion upon entry to the box.
Does the SVS box have a level meter, or at least a clipping indicator light? That would be useful to check if your analog input level is too low or too high for the A/D, and you could optimize the level by adjusting the volume control on your upstream receiver/processor.
post #32 of 35
Originally Posted by nicolasb View Post
In order to "put more effort into modelling the location of the other speaker than... the subwoofer" it would have to know that it is dealing with an "other speaker and a subwoofer".
OK. I should have written: "so maybe the SVS box puts more effort into modelling the location of the higher frequencies than modelling the location of the lower frequencies." As for the small frequency range where the satellite and subwoofer overlap each other, that's where the SVS box might have some difficulty. For example, if your crossover is at 80Hz, the sat is producing 80Hz at -3dB from one location, and simultaneously the sub is producing 80Hz at -3dB from a different location.
post #33 of 35
Yeah, you should.
post #34 of 35
I believe we'll see the "appearance" of a representative from Smyth to this discussion once an actual product actually becomes available for sale, which shouldn't be too much longer. Then we'll be able to get our questions answered directly, and should also be able to provide worthwhile feedback to them.
(looks at his watch impatiently)
When will that be, then?
post #35 of 35
Well, the Head-Fi show is May 3-4. I'm guessing probably within a month of that they may actually go "live".
And once they're public, I'm sure they'll participate. That's what I've been told.
No other news to report.
Hey... I'm still waiting for my long-promised serial #0001.
