AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › XBR 970 Owner Looking For New TV Recommendation!
post #1 of 4
As the title states, I currently own the Sony XBR970 and I'm looking for a bigger screen, 1080p, display that would basically be a larger version of what I already have with more detail (1080p). I would like to keep the budget below $1600 if at all possible. Can anyone steer me in the right direction?!
post #2 of 4
Anyone?
post #3 of 4
What is your seating position? If you are near 12 feet or more, you can go with the Panasonic 50PX80U (50", 768p), which will look just as sharp. However, for under $1600 their are plenty of 42" 1080p models for that price range. I would then suggest the Panasonic 42PZ85U (42", 1080p).
Chris
post #4 of 4
For just a little more the Samsung FP-T5084 might do the trick, 50" and full 1080P.
