AVS › AVS Forum › Audio › 2 Channel Audio › Need Good Receiver for RTi10 Speakers
post #1 of 5
Hey guys, i need help picking out a receiver (not a HT receiver) for my rti10 speakers. Is there any good one under 400? I plan to buy the hk3485 but just wondering if there is something better out there in the same price range.
post #2 of 5
Frankly, the most important differences, such as they are, will be in features. If you like the HK, buy the HK.
post #3 of 5
so would I see any improvent if I spend 450 on denon 3808? Which brand is better for stereo music? Denon or hk?
post #4 of 5
Improvement? None to little.
Best brand for stereo music? Any major brand.
If you want better sound, buy better speakers or improve your room's acoustics.
post #5 of 5
Under $400, you have several great choices, including stereo receivers from H/K, Onkyo, Marantz, Denon and Yamaha, and a few integrated amplifiers, including one from NAD. Any of these will be just fine. Your speakers and their placement, room acoustics, source, etc all have a much larger effect on the sound of your system.
