AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Marquette, MI - HDTV
Marquette, MI - HDTV - Page 5
post #121 of 193
Fall 2009 HD Local HD Launches
These are the markets expected to launch over the next two months:
September
Charleston-Huntington WV
Columbia SC
Huntsville-Decatur AL
Bluefield-Beckley WV
October
Jackson MS
Updated 9/29:
November
Marquette MI
Missoula MT
Minot-Bismarck-Dickinson ND
Sherman TX-Ada OK
pulled this from satelliteguys.us. They usually are cutting edge with these announcements. So you all won't be stuck with Dish Network for locals.
post #122 of 193
Of course. Marquette has had cable since the 1960's. At first cable had ABC, CBS, and NBC and later added PBS and then WKBD out of Detroit and that was it until the late 70's. If more of the stations were OTA in Marquette we would have More OTA viewers. Cable has been entrenched too long and there were, what some say, dirty deals with it in Marquette in the early 80's.
OTA has Never really been a choice here because of the entrenchment of cable.
Originally Posted by Jon Ellis View Post
1MW wouldn't solve the problem completely, but it would help a lot.
The real issue is that 91.5 percent of households in the Marquette market have cable or satellite. (http://tvb.org/rcentral/markettrack/...ion_by_DMA.asp) With just 8.5 percent of households relying solely on over-the-air signals, broadcasters in the market don't have much need to beef up their signals.
post #123 of 193
WZMQ still is NOT transmitting a program guide!!
post #124 of 193
Email Danny Hood. Go to the website http://www.wzmqtv.com/ and there is some contact link. Mention his guide isn't working over the air and on Zap2it/Tribune Media WZMQ isn't even listed!
post #125 of 193
WJMN was scheduled to be full power in November, now it has been pushed into next year some time, probably spring or summer with the bad weather. Note that the temporary station broadcasts with 9.8 kW ERP, the permanent station will have 1,000 kW ERP. WJMN will be on DirecTV in November according to a press release from DirecTV. The following is from an email I received from the WJMN engineer:
WJMN-TV New Information
1. WJMN-TV has been granted a Construction Permit on July 23, 2009 to build our new permanent DTV facility at our previous site South of Trenary, MI. Projected completion date summer 2010.
2. WJMN-TV will be available on Dish Network in August 2009.
DirecTV has informed us they intend to start their local service mid 4th quarter 2009.
3. WJMN-TV is currently broadcasting DTV from a temporary site Northwest of Escanaba. This temporary facility has an approximate range of 25 miles around the city of Escanaba
4. Our signal is now on UHF channel 48 but will be indicated on your tuner as 3-1 or 3.1. The best possibility for good reception is a good quality UHF outdoor antenna. The cable from the antenna should be RG-6. If you intend to use an amplifier the best place for an amplifier is as close as possible to the antenna.
5. Until our Trenary facility is complete aim your antenna at Northwest Escanaba. After our new facility is operating you will need to re-aim your antenna to our site South of Trenary.
Press Release
FOR IMMEDIATE RELEASE - August 12, 2009
DISH NETWORK TO PROVIDE WJMN-TV CHANNEL 3 LOCAL SIGNAL
Escanaba, MI – Starting Wednesday, August 19, WJMN-TV Channel 3’s local signal will be available on DISH Network.
β€œAt WJMN we are pleased to provide our content to the people of Upper Michigan via our partnership with DISH Network. Along with important coverage like local breaking news, severe weather and school closings, WJMN will feature programming from the CBS Television Network, America's Most Watched Network,” said Perry Kidder, WJMN President and General Manager.
DISH Network is currently testing the WJMN signal.
post #126 of 193
deleted
post #127 of 193
from the satelliteguys.us forum:
Latest report is that we could see all of the November launches on Wed, Nov 11th.
Two more weeks...
November
Marquette MI
Missoula MT
Sherman TX-Ada OK
post #128 of 193
Now available on DirecTV:
WLUC (NBC), WBUP (ABC), and WJMN (CBS) in HD
WBKP (CW), WLUC-DT2 (FOX), WZMQ (MYT), WNMU (PBS), WNMU-DT2 in SD
post #129 of 193
Does WLUC-DT2 (FOX) 6.2 broadcast in HD? Or is that only a SD channel over the air, too?
post #130 of 193
SD over the air and on satellite. Better than nothing.
post #131 of 193
Anybody have any idea when dish network will get the locals in HD? I signed up for dish network not knowing they were only sd, if I had known I would have gone with directv instead. Anyway, anyone have any info? I find this unacceptable especially with the superbowl coming up.
post #132 of 193
I just heard from Dish... "when pigs fly"
kidding, sort of.
post #133 of 193
Any news on WJMN and the Trenary tower? I call the 800 number and get ignored. It would be nice to be able to use my converter boxes again as WZMQ went off the air about a month ago and has not come back on so I am stuck with analog channel 7 and thats it.
Yep, 2010 and all I get is analog.
post #134 of 193
WJMN-TV website now says the transmitter is going to be installed in mid-August,will be working around mid-September.it's great to know WJMN people were on the ball and got this done in a very timely way isn't it.
post #135 of 193
You can't even get WNMU? either you live in the deepest part of the MQT bowl or you have a very poor antenna system. Do you have an outdoor VHF/UHF antenna with a preamp and RG6 coax? If not, try those.
post #136 of 193
on the bright side it will be the most powerful transmitter in the U.P. once/if it is up an running... they will put WLUC to shame.
sad it is more than a year after the transition and they are still running more or less a digital translator as a station.
post #137 of 193
I am in an apartment and using rabbit ears. I used to get all the major networks except ABC (which I got until they took the channel 28 (10) transmitter off the air.
I got channel 13 PBS analog in stereo on my circa 2004 Samsung and mono on my circa 1983 RCA.
Yes there is one cable company here but it has become expensive, bloated and clunky. I liked it better when they had 36 decent channels for $8.95 per month but that was the previous cable company (Bresnan). Cable has been around here since the 1960's and most people knuckle under and buy it because the "local" stations don't care about their signal coverage in Marquette.
Channel 13 PBS is actually the only station in Marquette but they don't broadcast their signal into here.
Channel 35/6/7 has a 25 watt transmitter in town which is what I am getting.
7 used to get stomped from time to time by a station in Sudbury Ontario from their tower in Wawa Ontario. So during the transistion there were times that I could not get a local station but I could get channel 7 out of Sudbury/Wawa(depending on propagation of course).
If the cable company would let me buy only the channels that I want I would sign up tommorow but that taint gonna happen.
post #138 of 193
Charter is a large enough company that they are required to offer a basic package that only includes the local channels, public access, home shopping, and a few others. They don't advertise it because they don't make much money on it. It's not really that cheap, though...with taxes it'd probably run $20-$25/month and you'd only get about 20 channels, half of it public access and home shopping.
post #139 of 193
Just like Citadel TV are blockheads for continuing to run their two low-banders on low-band (4 Quad Cities, 5 Central IA), the folks at Barrington that own WLUC aren't far behind. At least their low-banders went to UHF, but they seem content to leave transmitter power output about that of a toaster and a couple of hair dryers for WLUC and its other low-bander in MO.
post #140 of 193
Well, rabbit ears are only really any good for VHF. You may try putting a $30 amplifier in line to pull in WNMU. If you can't get that, then maybe your walls are lined with some sort of steel mesh.
Amplifier: get a low noise type such as the Channel Master 7777, 7778, or Winegard AP-8700. I know it's an outdoor preamp type, but it will work fine indoors and the noise level is like 5 dB lower than the crappy Radio Schmuck ones.
Antenna: for UHF, maybe try the Antennas Direct DB2 (could put on porch or it may be small enough inside... basically, you need something better for UHF...), just go here and browse:
http://www.solidsignal.com/cview.asp...=TV%20Antennas
See if you can put an antenna near a window or on an apartment porch. Rabbit ears only work when you are nearby pretty strong stations... and mostly VHF stations
post #141 of 193
WTOM (NBC) Cheboygan (also a Barrington station) is just as bad. You can't get it in the Eastern U.P. or in Gaylord. It's so pathetic they have to broadcast NBC on a tower (WGTQ) 20 miles across the lake.
post #142 of 193
Not worth the hassle. Why go through all that only to find that the signals really are not there. They were there when analog was around but with these great new digital signals they are broadcasting to the back of their eyelids.
Oh BTW I have been using a bowtie on both sets all along also.
ABTW Channel 19 is on cable so that leads me to assume that they lowered their transmitter power after they went off the air about 2 months ago.
post #143 of 193
If you look at the maps on TVFool.com you can see that he's right. WZMQ is the only digital station delivering a signal to Marquette that is strong enough to be received with an indoor antenna. Unfortunately, poor transmitter placement and low power levels have made broadcast irrelevant in Marquette. I was not even able to receive WBUP-10 when I camped at Van Riper State Park a few weeks ago, just 6 and 13 - with breakup.
post #144 of 193
Doesn't help that Marquette is a sharp 300' drop below the ground level where the transmitters are at. Indoor antennas are a thing of the past for over the air in the rough terrain of the NW'rn UP now. Guess you're S.O.L.
post #145 of 193
Duluth has a similar topographical challenge. However, they placed the transmitters on the edge of the hill in Duluth. In Marquette, they placed the transmitters inland in an effort to provide a better signal to Iron Mountain and Escanaba. They could kind of get away with that in the analog era, but digital is less forgiving. Not to mention the low power levels.
post #146 of 193
You've really hit the nail on the head. WLUC at 83kW was operating 100kW analog VHF. Comparable UHF digital for full powered stations is 1MW, similar to WFRV/WGBA/WBAY and what we'll see from WJMN by this fall. WBUP chose to go to channel 10.. not totally stupid, not really smart either. WWUP is up at 25kW from Goetzville. The close proximity keeps WBUP from increasing their power to 30+kW what WOOD/WWTV are running for VHF digital. WNMU-DT is only running 15.4 kW ERP, WBUP-DT is only running 9kW!
The Republic area is a good area for many transmitters due to the high terrain. The problem is that there are many hills between Republic and Marquette. I think we'd see better signal levels if the VHF stations in the area were on the order of 25kW and the UHF stations were 300kW or greater.
But, they can't afford it so that's how it is.
post #147 of 193
FYI
Topic added to main US list of markets. At long last.
post #148 of 193
Correction-
They used to have a strong enough signal. They went off the air sometime in June and when they came back on cable the OTA signal was gone. Either they changed their antenna or lowered their power or both.
That means I am only getting analog channel 7 and have been since June.
post #149 of 193
The stations broadcast from those inland transmitter sites (WLUC, WBUP and WNMU are also on a plateau) because they are closer to being equidistant to the three places in the Central U.P. where people actually live - Marquette, Iron Mountain and Escanaba, where they can get theoretical coverage of all three cities.
If those cities are in the blue circle, cable has to carry them. It does not matter that MQT and Esky are in bowls, Iron Mountain is behind an iron mountain, and they can't really be seen well over the air (and could not when they were analog - WLUC on 6 may have been seen in MQT okay decades ago, but not since they moved to their current site).
This is why they have/used to have translators in those cities when everything was analog.
post #150 of 193
Cable/satellite must-carry rules are based on market assignment, not actual coverage area. If the station is in the market, it can invoke must-carry status for any cable system and satellite provider serving the market. Coverage area is irrelevant.
WLUC is the only Marquette-market station with translators, and only in Marquette and Escanaba. WBKP did have a translator in Marquette for a few years until WBUP signed on. As far as I know WJMN and WNMU never had translators. (The Green Bay FOX affiliate has a translator in Escanaba.)
The theoretical coverage of Marquette is about as strong as the Chicago stations' theoretical coverage of Milwaukee, if that says anything. Here is a direct link to WLUC's coverage area:
http://www.tvfool.com/?option=com_wr...&q=call%3dwluc (It should be noted that the area in purple is pretty much useless unless you have your own tower.)
Hopefully this doesn't come across as confrontational, just trying to set the record straight...
