AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Can I use a component cable in place of an RCA temporarily?
post #1 of 10
I am picking up an amp today and wanted to know if this would work. I'll get some proper RCA cables but for today I really want to try this thing out. You know how it is, I just have to play with my new toy.
post #2 of 10
That's a good question. It probably would work. Only one way to find out, give it a shot! Let us know if it works.
post #3 of 10
Yes it will work just fine the thing that seperates video and component cables
from the rest of the rca group is those 2 are supposed to be 75 ohm and all
the others could be up or down from there, so yes it will work.
post #4 of 10
Yes absolutely. The reverse, however, is not necessarily the case.
post #5 of 10
Not only would it work temporarily, it will work permantly.
post #6 of 10
Yes, but it's just so gauche you know
post #7 of 10
Chu Gai
I know don't tell any one.
I thought it would work but since I wasn't positive I just wanted to ask. I've never messed with an amp but I have some B&W speakers that sound good but they are power hungry bast@rds and I feel I might be risking my AVR by driving it almost full volume.
post #8 of 10
Wow I can actually get some volume out of these B&Ws This is an old set that I just love the sound of they can really rattle the walls. I think I'm officially becoming addicted to a hobby. The speakers themselves were a big improvement but the Adcom is definitely taking it further.
Ok this sounds great. What do I need to do to this amp its an older Adcom GFA-1a I'm guessing 20 years old. I'm going to take the cover off and give it all a good cleaning. Tons of dust and crap on the heatsinks and fan. What do I need to watch out for when I do this? I've never done this to one is there capacitors I need to avoid and such?
post #9 of 10
Just clean it out with compressed air and a dry cloth. Don't use any liquids or cleaners.
post #10 of 10
Yeah that was my plan. I have a can sitting here now waiting for me to turn it off so I can get into it. After it cools down that is. I've been Jamming for a while now. I definitely know my speakers protection circuit works though. I caused them to cut out a couple of times.
