AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › PS3 to Macbook (or any other laptop) via bluetooth?
post #1 of 12
Is it possible to connect my Macbook Pro or IBM Thinkpad (or any other laptop for that matter) to my PS3 via Bluetooth, such that I can use the keyboard to type messages on the PS3?
I've tried scanning for devices on the PS3, but cannot seem to pick anything up. I am very new to the PS3, so, I'm not sure that I'm doing it right. (I haven't paired anything to the PS3 before).
post #2 of 12
That's a good idea, but I don't think it will work. I don't think there's any technical reason why it couldn't, but laptops just don't advertise themselves as input devices AFAIK.
post #3 of 12
I tried pairing my PDA to use as a remote but no luck either
post #4 of 12
is there a way to hook a ps3 up to the net through a laptop? i hate having to disconnect my laptop when i want to play cod4 online. i know i could buy a router, but if this could be done, it would be cheaper and more convenient. (download a lot of **** on my laptop, that's why it's inconvenient)
post #5 of 12
If you have a Mac, just go to SysPrefs->Sharing>Internet Sharing. Tell it to share your Internet from ethernet to computers using AirPort.
If you're using Windows, you might be able to install some software to do it, but I have no idea what that would be.
Edit: I'm assuming your PS3 has a wireless card.
post #6 of 12
yep.
post #7 of 12
Would the wifi be secured? (WPA-2)?
post #8 of 12
The only security option is WEP, either 40- or 128-bit.
post #9 of 12
128-bit is best?
I could get this to work with my PS3?
post #10 of 12
It should work just fine, 128-bit is better, but I don't know if the PS3 supports that. (The online manual doesn't say, and my 20 GB doesn't have wireless, so I can't check it myself.)
So yeah, you can do it, but it will be "reasonably secure," instead of "very secure." IOW, it will keep out casual leechers, but if someone reallywants to get in to your network, and they know what they're doing and have the proper tools, they probably could.
Basically, 40-bit WEP should be fine, assuming you're not trying to safeguard plans for stealth bombers, etc.
post #11 of 12
My 40G PS3 is using WPA-2.
Mark
post #12 of 12
Sorry, I meant when you're setting up Internet Sharing on a Mac.
Macs can connect to WEP/WPA(Personal/Enterprise)/WPA2(Personal/Enterprise), but out of the box, they can only set up a WEP network.
  Back to Forum: PlayStation Area
