AVS › AVS Forum › Audio › 2 Channel Audio › Stereo System with iPod Remote?
post #1 of 3
I will soon be in the market to replace my bookshelf CD stereo system with a good quality stereo system. Budget would be up to a few thousand dollars. My preference would be that this stereo system would have the ability to 1) doc my iPod playing lossless audio and 2) have a remote with an LCD screen and wheel that would mirror the iPod's menu functionality. Does such a beast exist? Thanks.
post #2 of 3
This is the only product I've seen so far, but perhaps there are more like it out there.
http://www.keyspan.com/products/tvi200c/
While not a complete stereo system, it seems like a worthwhile add-on.
post #3 of 3
I have a Bexy Imirror that does this. It has an RF remote that's relatively easy to use.
Functionality is OK, not great on the remote. And it is rechargeable on the dock.
Ok I misread the part about mirroring the Ipod Menu. It doesn't do that exactly it does go into playlists and genre and such. You can also play video from your Ipod through it. Although the quality would not be great.
