Hola folks,
After research regarding upscaling and the 805 vs a nintendo wii.. it seems that its worthless due to the aspect ratio refusing to stay widescreen. Means one of the intrigueing points of me buying the receiver is now next to worthless.
That aside, I'm having trouble getting audio to play from my television from the wii. I have everything ran into the receiver via hdmi that can be, and have no problems with any of it. The wii however is ran in via component, and the video.. albeit cant be upscaled properly, does display in its native reso on the tv. The audio on the other hand, I can not get to play on the tv. It has come to my attention that in order to u se the tv's speakers to play the audio, the cable will need to be hooked up directly to the tv. Although dissapointing, this is fine. Problem I'm now having is I'm unsure of where to put "in" the L/R on the receiver. I would hate to have to bypass the receiver all together for the wii, that would defeat the purpose but for now with no speakers, I would like to use it as a switch of sorts and still have audio via tv speakers. Anyone who is familair with the nintendo wii knows that nintendo's components are bound together by hard plastic tehrefore running them to different areas are impossible. The end on the nintendo side is also a custom plug so no using universal type cables either.
I apologize if this sounds jumbled.. but if someone can help me solve this or give me my options I would be grateful.
Thank you!
Thank you!
