My sub is emitting a nasty (and extremely loud) hum/buzz. It does this even when all components are turned off. Thinking it might be a ground loop issue, I began unplugging components and connections until I discovered the hum is drastically reduced by disconnecting the digital coaxial cable running from my DVD player to my receiver.
Are there any fixes to this specific issue of a coaxial cable producing sub hum?
