Originally Posted by
USCRx
ak3883,
1. How are you setting up the motorola 3416/d-r410 to be sure that a widescreen format is being sent? (I have the DVD-Rs)
4:3 override is set to "off" or disabled. Basically the box doesn't stretch 480i(all SD) channels. I have pillars on my TV at all times when watching SD channels. Doesnt' bother me, I'd rather not have everything stretched and distorted.
The D-R410 aspect ratio is set to "auto", meaning it records on the DVD in widescreen if the output from the box is 16:9(any HD channel) and records in regular 4:3 for any SD channel. Of course you need to be using a DVD-R to be able to record in 16:9 widescreen...
I'm assuming your games are in HD on the DVR... and since the box cannot output anamorphic widescreen, the picture is just plain widescreen, when watching even on a widescreen TV, there are black bars on the top and bottom. Kinda sucks but i'd rather have that than have stuff cut off on the sides.
USCRx
2. Also, are you set up with an s-video cable and an L-R cable going from the 3416 to the 410? Component from vhs to 410?
Yes, svideo and L-R cables from the 3416 to the 410. I use the HDMI output from the 410 to my AV receiver which switches all my inputs and outputs to my display. You could use component as well, wouldn't matter.
USCRx
3. When recording the games, you must watch in real-time. Is that correct?
Yes.
USCRx
4. By editing out commercials/half-time, do you mean that you are stopping then restarting the recording? If so, how is the transition when you rewatch the game. (flickering, stuttering, etc.)
Exactly, I'm pausing the recording(hit pause on the remote), then restarting it(hit record on the remote). Do NOT hit "stop" every time, or you will create new titles. I do hit stop after the 1st half though, so I have 2 titles on the disc, one for the 1st half and one for the 2nd half(or quarters, or whatever)There is no flicker or studdering, odds are you won't get it exactly right every time, so in the recording there will probably be a split second image of the first commercial, then a cut right back to the game. It's seemless though, no flickering, studdering, etc. Other DVD models can be set to insert chapter marks when you pause the recording, unfortunetly the D-R410 cannot.
USCRx
5. If you choose not to edit out the commercials on the original recording, then you can rip the finished dvd to the computer, then edit/author them afterward? What software can you use in addition to shrink.
Others can answer this better, I have not purchased DVD authoring software. I have used a somewhat stripped down version of Sonic MyDVD that came with my older DVD burner, it worked ok. I made a DVD of MPEG movie files already on my PC. Obviously you can custom make a menu background, add music, do chapter marks, etc and it makes thumbnail images for the DVD menu. But for recording a game straight from VHS, it's not worth the hassle of recording to the PC first, getting the quality settings perfect, etc etc. This would be better for making a compilation of several smaller clips or shows from multiple tapes.
