AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Official Panasonic DMR-EZ48VK thread
Official Panasonic DMR-EZ48VK thread - Page 44
post #1291 of 1498
Originally Posted by catchyoulater View Post
...I will try your suggestion tomorrow. I can upload photos of the backs of the equipment, altho you know what the Panasonic looks like. I took the pics to Radio Shack and of course the guy tried but had no clue.
The first photo is a rear view of the earlier, similar DMR-EZ47 (from the 2007 model year). The inputs and outputs are somewhat basic. Notice that the composite "DVD/VHS COMMON OUT" provides VHS and DVD signals while the composite "DVD PRIORITY OUT" provides only the DVD output.
While I have no familiarity with DirectTV receivers I would think that they have the usual set of outputs. This will include (digital) HDMI and (analog) component red, green, blue outputs for connection to a HDTV. The HDMI carries video and audio while the component connections carries only the video. When component outputs are used the white/red audio connections are also necessary. There will certainly be a composite video output, the yellow connection, and perhaps there will be a S-Video output, a round black connector with several pins. The composite video and S-Video both require use of the white/red audio outputs. Perhaps the DirectTV receiver might have a threaded RF coax cable output that carries the video and audio.
If more than a single set of white/red audio outputs are needed use "Y" adapters, as seen the second photo, to split the DirectTV receiver's single set of audio outputs.
Sometimes satellite receiver or cable box outputs are not "active." By this I mean that they may not be functional until one goes into a configuration menu to set the output to "ON" or "ENABLE" or "ACTIVATE" or some such term. That information should be in whatever instruction sheet or user guide was provided with the DirectTV receiver.
post #1292 of 1498
Thank you, guys! I sure wish I had your knowledge! So here are photos of the backs of the TV Set (an RCA big screen HDTV Monitor), the DirecTV HD DVR receiver and the panasonic.
He's got the DirecTV dvr attached directly to the TV set.
UPDATED QUESTIONS: on back of the DirecTV STB what are those green, blue and red cables for? And they're attached to the CMP1 in back of my TV set. What do these do? Carry video only? What are those two fatter cables just below the back of the Direct box green, blue and red cables which are also attached to the back of the tv set but to the right of the 3 cables in the CMP1.
What is the CMP1 in back of the set? what is that for?
Is it possible to plug in an s-video connector to the s-video in on back of the tv set then connect the other end to the s-video out on back of the direct box? then connect the L and R audio cables (are those red and white ones?) in back of the TV set to the red and white L & R on back of the direcTV box under audio out then connect the red, white and yellow components on back of the direct box (removing the green, blue and red one) to the video and audio in on back of the dvd burner? Would that work? Or do I need those green, blue and red cables as the two fatter cables?
post #1293 of 1498
This should be pretty straightforward.
The connection between the DirectTV receiver output and the DMR-EZ48 input will use the yellow composite output (just below the component red, blue green connections on the DirectTV receiver). Then use two "Y" adapters to spilt the white/red audio outputs (those just to the right of the yellow video connection on the DirectTV receiver). That will provide two audio feeds, one to the TV and the other to the EZ48. Then connect a set of EZ48 outputs to a set of vacant inputs on the TV. Then use the TV's remote control to toggle between the inputs where the DirectTV receiver and the EZ48 are connected.
post #1294 of 1498
It looks like you've already got Y-splitters on your STBs audio out and if you use a S-video instead of composite(going from your STB to DVDR) you should see a better picture for recording.
If it were me I'd use component from your EZ-48v to TV for DVD viewing and composite(from the common out) for VHS watching.
If you wanted to purchase a DVI to HDMI adapter or cable you could run that from your EZ-48v to your TV(along with stereo audio cables) in which case you could do away with the composite video and stereo audio along with the component video and stereo audio cables. The HDMI out of your EZ-48v carries both VHS and DVD outputs. HDMI also carries audio but your TV doesn't look to have a HDMI input and DVI doesn't carry audio, you must use separate audio cables.
If looking for cheap(but good) cables, check out Monoprice.com. Click the link at the top of most AVS pages. You could get all the cables needed for less than one cable at most retail prices.
P.S. I'm envious of your TV, I see it has audio outputs (for speakers), I've never seen that before and I'm always forced to open my new TVs and install such outputs since I don't like the speakers built into flat screen TVs. Generally the audio output circuitry of flat screens are decent, it's just the small speakers leave lots to be desired. A pair of bookshelf speakers does wonders.
post #1295 of 1498
Originally Posted by DigaDo View Post
... Then use two "Y" adapters to spilt the white/red audio outputs (those just to the right of the yellow video connection on the DirectTV receiver). That will provide two audio feeds, one to the TV and the other to the EZ48...
There are several configurations of "Y" adapters. Be sure to obtain the "Y" adapters with one male and two female connections. A closer view is seen here:
post #1296 of 1498
In addition to the excellent advice from DigaDo and jjeff, if you live in an area that has OTA (over the air) broadcast TV available, I would hook an antenna to the RF input on the video recorder. You can then use the timer record function on the EZ48 to record OTA programs without having to change channels on the satellite box.
post #1297 of 1498
That is the y adapters I got from Radio Shack and returned because they didn't work like the installer said they would. Maybe he had me attach them in the wrong place.
Am trying to follow all this... where to connect which cable to what device. Anyway I can get a rudimentary diagram? BTW, those pics of the y adapters were before I took them off and returned them. I should have taken a new pic this morning with the way it is now hooked up.
Meanwhile, friend is here for a breakfast run... be back later. Thank you so much for helping me.
I'll post a new pic of how the DirecTV receiver looks now in about an hour.
post #1298 of 1498
The bottom two cables (where you see the first one is red) are connected directly to the TV set. Where do I move those?
post #1299 of 1498
Originally Posted by jjeff View Post
...if you use a S-video instead of composite(going from your STB to DVDR) you should see a better picture for recording.
From the photo it isn't entirely clear that the S-Video is an output. Might this be an input, and if so, for what purpose?
post #1300 of 1498
What is the STB? S-video on the DVR or the DVD player?
Well there is one s-video on the DVR, doesn't say in or out and two s-videos on the DVD player, again neither says in or out!
post #1301 of 1498
In the second photo in the post just above yours, the s-video plug is next to the yellow video composite plug, so it's safe to assume it's an output.
I've never heard of sat boxes having line inputs before.
STB stands for Set Top Box, just a reference to any box that sits atop or near a tv.
As for the s-video pluhs on the ez48, there should be thin outlines around the Output and Input plugs, separating them, letting you know which to plug something into for Line input recording, and outputting the 48's s-video feed to the tv.
post #1302 of 1498
Unplug those two white/red cables. Then, in their place plug the two "Y" adapters into those white and red jacks. Then reconnect the original white/red cables into one side of each "Y" adapter. The other end of those cables will remain plugged into the TV white/red audio inputs. Then, with another pair of white/red cables plug them into the unused side of each "Y" adapter. The other ends of that white/red cable set will be plugged into the white/red audio inputs of the EZ48.
To maintain correct stereo orientation you need to remember which of the "Y" adapters is the white side (left channel) and which of the "Y" adapters is the red side (right channel). One way to remember this is to twist a short white wire-tie around the "Y" adapter cable plugged into the white jack, like this:
post #1303 of 1498
Hmm, I thought that's what I did yesterday. It sounds like what the installer told me and yet it didn't work.
well, I'll go back to Radio shack and pick up those Y connectors again.
post #1304 of 1498
See photos above:
post #1305 of 1498
See photos above:
They carry the high definition video signal.
Yes, video only. The Red/Green/Blue cables are known as component video cables. Each of the different color cables carry a different component of the picture separately.
The CMP1 jacks on your TV are for your Component Input #1. To watch anything hooked up to the CMP1 input you will need to change the input on your TV to Component 1 or CMP1 or something like that, depending on how it's worded on your TV.
Those are the left and right audio cables. White is for the left speaker and red is for the right speaker.
You could, but the component video cables should give you a better picture than S-video. On most hardware the S-video output won't be high definition video, but often component outputs will be high definition.
The L and R audio cables should be connected to the corresponding audio jacks where the video cable(s) go. Often you have more available video outputs than audio outputs. That is why we sometimes need to use the Y-adapter cables.
The yellow video cable is called composite video. All of the picture components are carried on the same wire in a composite signal. It's not known to be of high quality, but sometimes we don't have any other option. Fortunately you have much better options.
I prefer to use the R/G/B component inputs and outputs wherever possible. The second choice would be S-video, and third choice would be the yellow composite video cable.
post #1306 of 1498
See photos above:
My post #1292, just before your post #1293, addressed these matters. Here is the pertinent portion of post #1292:
"While I have no familiarity with DirectTV receivers I would think that they have the usual set of outputs. This will include (digital) HDMI and (analog) component red, green, blue outputs for connection to a HDTV. The HDMI carries video and audio while the component connections carries only the video. When component outputs are used the white/red audio connections are also necessary. There will certainly be a composite video output, the yellow connection, and perhaps there will be a S-Video output, a round black connector with several pins. The composite video and S-Video both require use of the white/red audio outputs. Perhaps the DirectTV receiver might have a threaded RF coax cable output that carries the video and audio.
"If more than a single set of white/red audio outputs are needed use "Y" adapters, as seen the second photo, to split the DirectTV receiver's single set of audio outputs.
"Sometimes satellite receiver or cable box outputs are not "active." By this I mean that they may not be functional until one goes into a configuration menu to set the output to "ON" or "ENABLE" or "ACTIVATE" or some such term. That information should be in whatever instruction sheet or user guide was provided with the DirectTV receiver."
After your photos appeared in post #1293 I responded with this advice in post #1294:
"This should be pretty straightforward.
"The connection between the DirectTV receiver output and the DMR-EZ48 input will use the yellow composite output (just below the component red, blue green connections on the DirectTV receiver). Then use two "Y" adapters to spilt the white/red audio outputs (those just to the right of the yellow video connection on the DirectTV receiver). That will provide two audio feeds, one to the TV and the other to the EZ48. Then connect a set of EZ48 outputs to a set of vacant inputs on the TV. Then use the TV's remote control to toggle between the inputs where the DirectTV receiver and the EZ48 are connected."
In post #1303 I provided additional advice:
"Unplug those two white/red cables. Then, in their place plug the two "Y" adapters into those white and red jacks. Then reconnect the original white/red cables into one side of each "Y" adapter. The other end of those cables will remain plugged into the TV white/red audio inputs. Then, with another pair of white/red cables plug them into the unused side of each "Y" adapter. The other ends of that white/red cable set will be plugged into the white/red audio inputs of the EZ48.
To maintain correct stereo orientation you need to remember which of the "Y" adapters is the white side (left channel) and which of the "Y" adapters is the red side (right channel). One way to remember this is to twist a short white wire-tie around the "Y" adapter cable plugged into the white jack..."
post #1307 of 1498
Thanks, Digado and Ken; I just want to be sure I understand the function of those cables. I still have to go back to Radio Shack and repurchase those splitters. It didn't work the first time but perhaps I had them hooked up incorrectly (well, obviously since it didn't work!).
I'll get those splitters then carefully follow all your advice. Hopefully tonight.
I must say I am enjoying the DirecTV service, lots of channels, and their DVR can tape two shows at one time! Beautiful! No more having to decide which one to choose. The HD picture is quite good, I especially enjoyed watching my Dodgers in HD yesterday! So guess this was worth the change and the angst.
I just knew when I switched from Dish to DirecTV this DVD/VCR would get left out in the cold. You'd think for a new customer they'd have reconnected my system as they found it. I don't think I was asking for anything extra or special in my setup.
So far, DirecTV customer service leaves a lot to be desired. Not off to a good start.
post #1308 of 1498
Note if you're STB outputs Wide Screen over S-video you will get a much better picture recording WS material than if it only letterboxes WS. Sometimes you may be able to go into the STB setup and specify if you want WS or letterboxed WS output for SD outputs(choose WS).
Note some boxes do NOT allow WS over S-video, cable boxes are notorious for this although it seems Sat. boxes generally allow WS.
post #1309 of 1498
Thanks for the tip, JJeff. Would looking at the back of the DirecTV DVR receiver (see pics in above thread) tell you if I'd be able to do that? I love WS, I'll also check in setup as well. But first I need to get my DVD/VHS burner player connected!
post #1310 of 1498
No looking at the back won't tell you if it will output WS over S-video. The easiest way to check is run a S-video(or composite) cable directly to your TV. If you see WS(without black bars on top and bottom) you in luck. If it's letterboxed(black bars on top and bottom) you need to start looking in the STB setup screens.
post #1311 of 1498
I used the Y splitters. I hooked everything up like you said in the paragraphs above. And using the DirecTV remote control to toggle over to VID 1 (the Panasonic's wouldn't work) I can view both VHS and DVDs! Alas, I cannot tape or record anything! I usually love to burn to DVD programs off the DVR that I decide to keep and from time to time I use the VCR to tape a program for a friend to give to them to keep. So I still can't do that. Help
So any suggestions?
post #1312 of 1498
So any suggestions?
When you mention using the DirectTV remote that must mean that you've set up that remote to control your TV as well as the DirectTV tuner. Is that correct? That allows you to toggle between the TV inputs where the DirectTV and EZ48 are connected. So far, so good.
Assuming that the correct connections have been made between the DirectTV outputs and the corresponding DMR-EZ48 inputs, the Panasonic remote will need to be used to select the input where the DirectTV feeds it's signal to the EZ48. With the Panasonic remote's INPUT SELECT button repeated pressings toggle through the inputs.
There was discussion of using the DirectTV yellow video output or the S-Video output, either of which require that the DirectTV white/red audio outputs are connected to the corresponding inputs on the EZ48. If those DirectTV outputs are connected to the corresponding inputs on the EZ48's rear panel the IN 1 would be selected with the EZ48 remote's INPUT SELECT button; if the connections were made to the EZ48's front panel the IN 2 would be selected with the Panasonic remote's INPUT SELECT button.
Once the EZ48 is set to the correct input the DirectTV output may be viewed/recorded through that EZ48 input. Be sure to leave the EZ48 set to that input as the EZ48 has now been enslaved to the DirectTV tuner. The current input setting before entering the SCHEDULE menu becomes the default input when timer recording data is entered.
post #1313 of 1498
Yes. The installer set up the DirecTV remote to control the TV and the DirecTV tuner.
I tried briefly this morning to do that but the panasonic remote INPUT SELECT would only go to something called C1 then it stopped. There was still no picture.
I'll have to try the s-video when I get home from work.
One more question; do you think if I connected those green, blue and red cables from the DirecTV tuner directly to the EZ48 that might be a good solution? then ran an output set from the EZ48 to the TV set? I'm probably way off base here, since I have very little idea of what I'm doing. But thought I'd ask! Thanks!!!!
post #1314 of 1498
That's fine. At this point let's stick with basic connections/procedures and avoid random experimentation.
When pressing the EZ48 remote's INPUT SELECT button a small menu box will open showing these choices, "TV" (meaning the RF input--not relevant to your set-up), "IN1" (meaning the rear panel S-Video or composite yellow input and adjacent white/red audio inputs), "IN2" (meaning the front panel S-Video or composite yellow input and the adjacent white/red audio inputs), or "DV" (meaning the DVI input, a small jack behind the fold-down door on the front panel--not relevant to your set-up).
Since the EZ48's internal tuner is irrelevant when using the DirectTV tuner, the INPUT SELECT must be set to the INPUT where the DirectTV tuner feeds it's signal to the EZ48.
Ordinarily, with a Panasonic DVD recorder a "C" followed by a number message indicates a tuned "channel" but there is no "channel 1" so I'm at a loss to explain how the EZ48 might generate a "C1" message. Most likely, the "C1" message is being generated by the TV itself, indicating that the EZ48 is connected to the TV's "Composite #1" input.
If you've already made the composite yellow connection from the DirectTV output to the EZ48's yellow composite input that should be sufficient to make your set-up functional. Later, if you want to upgrade to S-Video you may do that, but the present concern is basic functionality.
The DirectTV green, blue and red jacks are component OUTPUTS for connection to a HDTV, not to a DVD recorder. The green, blue and red jacks on the EZ48 are also component OUTPUTS for connection to a HDTV. Current and recent model DVD Recorders do not have green, blue and red component INPUTS.
post #1315 of 1498
I am not getting any image on the TV screen. That C1 msg was on the front of the DVD player. And that's all I'm seeing. Nothing from the ez48 shows up on screen, no menu, no setting controls for the ez.
Someone here at work suggested my problem is that I have a HD steam trying to go to a SD device and there's no conversion happening. That the DirecTV box may not enable it due to the HD connection.
I think I'm going to try your suggestion as well as the s-video connection and as a last resort throw in the towel on the HD receiver and ask them to send me a SD receiver DVR and the heck with HD!
post #1316 of 1498
The DirectTV tuner outputs "digital" High Definition video through it's HDMI output and "analog" High Definition video through it's component video (red, blue, green) outputs. The other DirectTV tuner video outputs, S-Video and yellow composite, are "analog" Standard Definition video, not High Definition video.
In two of my earlier responses I made this observation:
Have you checked the DirectTV tuner setup and/or configuration menus to determine if the composite video (and/or S-Video) outputs are set to "ON" or "ENABLE" or "ACTIVATE" or some such term?
With some equipment enabling a certain feature results in disabling another feature. My experience is with cable (and OTA), not satellite. Sometimes cable equipment has to have certain features enabled by service or technical personnel, not the customer. That might also be the case with DirectTV.
post #1317 of 1498
No, I haven't checked that yet; I'll try that as soon as I get home!
I may have to call customer service and ask them if this is the case. I have noticed that this receiver is so new that they don't even have it listed on their website nor to they have PDF manuals on site for it.
post #1318 of 1498
Not necessary. All DirecTV receivers (including your new HR24) have no such setting. All outputs are always active (and wide-screen as well, by the way). I used an EZ48 (and EH75, EZ17, EZ27, EZ28, etc.) with DirecTV for years without issue and never had to change any settings.
You likely either haven't connected the panny to your tv correctly or you haven't selected the correct input on your tv. So dig into your tv manual and find out how to select (or possibly enable) the different inputs. Don't give up that HR24 under any circumstances (I would kill to get my hands on one of those myself). It's the best DVR DirecTV has ever made and works beautifully with any DVD recorder.
To summarize, here's what you should have:
- DirecTV S-video Out and R/W audio Out from your Y splitters to S-video In and R/W audio In on your Panny
- Panny S-video Out and R/W audio Out to S-video In and R/W audio In on your TV
All other connections remain the same as the installer left them.
On your TV, you need to figure out how to select the S-Video input to watch the panny and how to select the component input to watch DirecTV. On the panny you need to figure out how to select the S-Video input to record.
Not to put another fly in the ointment. But once you get it figured out. You may want to start using the DVI input on your TV for the Panny instead of S-Video. Just get an HDMI-DVI cable from monoprice.com and connect from the HDMI out on the panny to the DVI in on the TV. In that case use the R/W audio inputs next to the DVI connector.
post #1319 of 1498
LOL, thanks for the pep talk. Okay, I won't throw in the towel. Am glad to know there is no such setting on the HD DVR. But it's so frustrating. Each new device gets more and more complicated.
I will fiddle with it all again tonight.
post #1320 of 1498
For the tv, shouldn't that be a simple matter of dial the ch up button from channel 2 to reach the Line inputs? Or ch up or down from the current input. He's obviously seeing DirecTV, so the other input chs should be next to the one with Direct.
Anyways, here's what to look for on the ez48 once you get it hooked up correctly.
Picture 1-Input Select box. Pressing the Input button under the ch up/down button, this is what you'll see. Use the arrow buttons to move to Input 1 or 2, press OK, to see the Directv feed on the ez48.
  Back to Forum: DVD Recorders (Standard Def)
