Originally Posted by dkasilag
I really need help, please...
This is my present system. DirecTV HD receiver to Onkyo 674 AV Receiver to Panasonic Monitor (I'm using only component BNCs). So I want to add the EZ48V. I bought it at Best Buy and I they sold me a Dynex RF Modulator too. When I opened the Dynex Modulator, it doesn't make sense to me, where will it go? It's inputs are RCA and the only out is the RF Coax. So where should I connect this COAX? Do I REALLY need this RF Modulator? (MyTV is just a monitor, no RF/ANT input.
I didn't hook it up, instead, went straight from DirecTV HD receiver to Panny EZ48V RCA input and out to Onkyo AV receiver.
I want to record some DirecTV shows to Panny DMR-EZ48V. I did the hook-ups but it seems something is terribly wrong. On thing good, is I can see DirecTV and play a DVD on the Panny EZ48V. (Does it mean, I did the wirings right?) What about the RF Coax? the diagram says, I need to hook it to the TV, do I really need to since I have none of this in my monitor?
Any help will be highly appreciated.
-Bernie
-Bernie
The RF output is for cable or antenna 'Over the Air' signal pass thru to a tv with it's own analog or digital tuner, so that the tv can recieve either cable or the OTA digital signals without the 48 being tuned on.
Since you have an AV receiver, I don't think you'd need a modulator, unless you need more connections for other video equipment (another dvd player, or vcr) than your receiver possesses.
The DirecTV feed should come in on the ez48's line input, so is that where you can see the DirecTV picture when you've got the 48 tuned on? If you can see the feed over the line input, then you should have no problems recording from it, unless the program has some copy protection signal transmitted with it.
I could be wrong, but I thought when set to 4:3 that the tuner just truncated the sides instead of actually letter boxing the output. For this reason even when I had my EZ recorder hooked to a 4x3 TV I kept that setting on 16:9. The downside was everyone looked tall and skinny.
Maybe they fixed it.
