AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Subwoofer Cable Suggestions Please
post #1 of 10
Hi everyone. I have a new M&K VX1250 on the way and need a cable for it. Needs to be 40-50' long to go into my 5.1 receiver. Want a good cable but do not want to second mortgage the house though in order to afford it. Probably would like to stay around 50 bucks or so. Can anyone recommend brands, model numbers, site addresses where I can order? Would really appreciate the input of you gurus out there. Thanks a million.
post #2 of 10
I cant post the url,but theres a 50' sub cable on amazon for 17.99
post #3 of 10
http://www.amazon.com/Total-Signal%C.../dp/B000B67ELG
There ya go ...I got my 3rd post..yay
post #4 of 10
Check out MonoPrice.com. They have really good cables for great prices.
post #5 of 10
Thanks for the suggestion. I did check them out but they only have 1 model in stock that is 50' and it was around 8 bucks, sounds a little low which makes me question the quality?
post #6 of 10
I'm using Monoprice's "High Quality" 50 foot subwoofer cable in-wall, then have 10 foot out of wall. Seems very well made and works great.
post #7 of 10
Thanks guys for your time and help.
post #8 of 10
Read this thread and then buy the one from monoprice. I bought every cable I needed for my HT system from there for 70 bucks, and everything seems well made and works perfectly.
post #9 of 10
your just talking about the sub freq's, monoprice is great and affordable prices, unless you want to pay for expensive unneeded cables.
post #10 of 10
Buy 50' of RG6 and put a rca connector on each end.
