Introduction
The purpose of this investigation is simply to compare several versions (clones) of the Black Widow DIY screen paint mix, to a commonly available reference gray paint. The focus will be on the Black Widow (AAA) that is made up of a 4:1 ratio of latex paint tinted PPG The Voice of Color "Bermuda Beige" 427-2 and Auto-Air Aluminum Base "Fine". A total of 8 clones will be included in these comparisons.
The purpose of this investigation is NOT to prove or disprove any of the claims being made by either the developers of the Black Widow mixes or the adopters who have implemented a Black Widow screen for their personal use. This investigation will be a balanced fair assessment of the performance of this aluminum based mix as compared to a simple near neutral gray wall paint with a matte finish. Every reasonable attempt has been made to either control or accurately characterize the environment in which these comparisons will be performed.
There will be two forms of comparison presented in this investigation. The first is carefully setup visual comparisons. It was impossible to create exact symmetry in the projected test images therefore each BW Clone will be compared to the Reference Gray in both the left and right positions. These are the least technical comparisons and only require the reader to look at the photographs and come to their own conclusions.
The second type of comparison will be done through the use of an image RGB sampler application. In this case I used the free application ColorPic. This is a very easy to use tool that does not require that images be down loaded or opened in a photo editor. It simply displays the RGB values that are under the cursor.
While great care was taken to ensure each sample panel was exposed to the same projected image there are some variables beyond control in my particular environment. The ideal environment would be a room with all flat black surfaces and a very high quality projector with zero variation in the projected light across the entire screen. This of course is not the environment that I have at my disposal. Therefore some steps have been taken to characterize the light variances and to compensate for them. This sort of variance or offset measurement and correction is only possible for ColorPic RGB samplings of the photographic data acquired during the comparisons. Please note that these are only the RGB values present in the image data. These RGB values do not represent RGB Color data for the screen surface in the image. This sort of RGB sampling is only useful for augmenting the visual assessment and is only useful for comparative measurements.
The Clones Black Widow (AAA) Behr 1050 Behr Premium Plus
Interior Flat - Ultra Pure White - #1050
Tinted: PPG Bermuda beige (427-2)
To Be Mixed (4:1) with Auto-Air Aluminum Base "Fine"
Black Widow (AAA) Behr 4850 Behr Premium Plus ULTRA
Exterior Flat - Ultra Pure White - #4850
Some water was added, no more than 4oz/quart.
Black Widow (AAA) BenMoore Benjamin Moore Collection
Interior 100% Acrylic Flat Enamel
Pastel Base #F602 1B
Black Widow (AAA) CIL-Matte C-I-L Smart3 Wash & Wear
100% Acrylic Interior Paint
Ultra Matte - #88100 - Brilliant White
Black Widow (AAA) Olympic Olympic Flat
Black Widow (AAA) Pittsburgh Pittsburgh Paints Pure Performance Flat
Interior Latex - Pastel Base - #9-110
Black Widow (AAA) SICO SICO Flat Acrylic Latex
Interior - Natural White - #171-14
Black Widow (AAA) Valspar Flat Valspar Ultra Premium "Flat"
Black Widow (AAA) Valspar Flat Enamel Valspar Ultra Premium "Flat Enamel"
Black Widow (BJA) Behr 1050 Behr Premium Plus
To Be Mixed (4:1) with Black Jack Aluminum Paint
The sample panels were prepared by applying 2 coats of Kilz2 to the sample panel followed by 2 coats of the BW-AAA mix. There were two exceptions to this. The BW-AAA-Behr4850 and the BW-AAA-CIL-Matte were prepared with a small amount of water and applied over one coat of generic white primer. Index: - Room Setup
- Light Metering
- Consideration Of Projector Calibration
- Uniformity Of Ambient Lighting
- Uniformity Of Projected Light
- Applying Offsets to Whites & Blacks
- Selecting A Reference Gray
- Projector Calibration
- Closer Look - Surface Texture
- Aluminum Flakes
- Pixel Grid
- 200x Microscopic View
- 60x Micropscopic View
- Comparison Source Images
- Visual Comparisons - BW-AAA-Behr1050
- BW-AAA-Behr4850
- BW-AAA-BenMoore
- BW-AAA-CIL-Matte
- BW-AAA-Olympic
- BW-AAA-Pittsburgh
- BW-AAA-SICO
- BW-AAA-Valspar-Flat
- BW-AAA-Valspar-Flat-Enamel
- BW-BJA-Behr1050 (Black Jack Aluminum Paint)
- BW-AAA-Valspar-Duramax-Flat
- Closer Look At BW-AAA-Valspar-Flat-Enamel - Surface Texture
- Density of Exposed Aluminum Flakes
- Aluminum Flakes & Pixels
- 60x Microscopic View
- Flesh Tone Evaluations
- Ambient Light Performance
- Shadow Detail Evaluations
- Comparisons To Black Widow (AAA) Valspar Flat Enamel - Valspar Flat Enamel Tinted "Veil"
- Black Widow (AAA) Valspar Flat
- Black Widow (Black Jack Aluminum) Valspar Flat Enamel
- Black Widow (AAA) Valspar Exterior Duramax Flat
- Black Widow (AAA) Behr #4850 Exterior ULTRA Flat
- CIL DULUX Exterior Stucco, Masonry, & Siding, Flat Tinted "Veil"
- CIL DULUX Exterior Stucco, Masonry, & Siding, Flat Tinted "Veil" ~vs~ Black Widow (AAA) Valspar Flat
- Conclusions
Appendix - Water Dilution Experiment - BW-BJA-Olympic-Flat
- Light Metering
- Aluminum Flakes
- Pixel Grid
- BW-AAA-Behr4850
- BW-AAA-BenMoore
- BW-AAA-CIL-Matte
- BW-AAA-Olympic
- BW-AAA-Pittsburgh
- BW-AAA-SICO
- Conclusions
