Originally Posted by BritInVA
So whats lastest on damage containment/repair Tom. Does the drycore look saveable?
Incidently made a inspection of my sump pit over weekend. I've never heard it run. I'ts a submersable so not sure if makes any noise!
Well anyway there was water in pit (not surprising with weather of late) but about 18" below slab. Got some buckets of water and topped it up. Never heard anything, did not see water movement or ejection at outlet so thinking pump is MIA. Just lucky I have walk out and water table below grade I guess. But think I may investigate further and replace pump.
Ah yes, just as pumps can fail from over use they can fail due to inactivity as well. Either type of failure can be a catastrophe. I know that even the quietest pumps can still be heard by a low hum. Then there is the clunk from the check valve.
Definitely get that pump replaced. You just never know.
Logan, I too am curious how your recovery is going.
RTROSE
With all of your progress I am feeling some much needed motivation. Thanks
