Originally Posted by tlogan6797
You'll also notice that there is a gap at the bottom of the frames. That is above the high water mark I've seen in that part of the room. The reason I wanted to build hang-able frames in the first place was in case of another flood. I thought I could take them down and save them. With carpet and a baseboard it will be fine. I hope.
YIKES! Here's to hoping that plan is never needed!
