12/29/2008
Tonight after procrastinating on the forums... I went down to clean up the mess hole..
Next, because of all of the earlier trim questions, I figured I would paint all the trim I needed plus a spare for the office area... then I realized that last night during my "break" I went online and updated my thread... then fell asleep.
I forgot to wash out my 20$ Purdy paint brush!!!!!!!!!!!!!!!!
After spazzing out for a second, I realized a trick my neighbor Mark's wife had taught me, saved me! She taught me that if you wrap a roller or brush up in plastic, it seals itself and the paint will not dry. Just out of habit I have done it like that ever since. I checked the brush and sure enough, it had sat out all night and was not one bit dry!
So major tip for those who care about your brushes
So after cleanup, I began painting and took the before and after pics (Some were a failed first coat attempt I sanded down for this repaint).
Before:
After:
In regards to the earlier questions, I tried and tried to take pictures of the small gaps that can occur between the drywall and trim, but the stupid camera wants to flash and will not show the shadow...
I did take a picture of the 45 degree splice for long walls. Ignore the chip on the top when I dropped it, it will be a quick 2 minute fix
Before:
After:
