AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Rca Dta800b1*
Rca Dta800b1* - Page 4
post #91 of 104
I was searching for this product based on reviews on cnet. Lot of people have been searching for this product or at least seemed that way from a lot of requests for this product. Walmart is carrying this product. You will have to purchase it "IN-STORE". Please note that not all stores have them. I had to go to a 2nd store to find it.
Also there was some confusion about model number. The sticker on the counter shows DTA800 but the cover on the RCA retail box clearly indicates the model number for DTA800B1.
The price for the product is about $50 here in Baton Rouge, LA. But, with tax it comes to about $55. If you have a $40 government coupon it's about $15 to shell out of your pocket.
Good Luck and Happy New Year to All !!
post #92 of 104
I have the DTA800B1 with a Panasonic CT-27G22UV TV. I get the 'instruction' video, but I can't get the box or TV to get any channels.
The manual says to go to the 'No signal' screen and punch in 562. What or where is the 'no signal' screen?
thanks,
Jim
post #93 of 104
I had/have both the RCA DTA800B and the RCA DTA800B1 and I can confirm that the tuner is a little more sensitive w/ the newer DTA800B1 version given the EXACT same setup. I also have the Zenith DTT901 and I think the tuner of the DTA800B1 may not be quite as sensitive, but I can not be sure. I'm not worried enough about it to check it. For certain, the tuner w/ the Zenith is top notch even if some of the other parts of its design are not the most thought out (on box volume, for example).
post #94 of 104
I have a dta800b1 but am wondering if I should get a dta809. On widescreen mode on some stations I get black bars on the sides and top and bottom of the tv not just top and bottom!, switching to another station is quite slow, the color is a bit off and I can't delete useless stations. Did they improve these flaws with the dta809?? I'm going to get a smart antenna because I have lots of weak stations from differnt directions.
post #95 of 104
I'm assuming the sales tax rate is closer to 10% and not 50%. So why do you have to pay sales tax on the $40 the government is paying?
post #96 of 104
The DTA800B1 only has two aspect ratio settings, letterbox and zoom, even though the government requirements indicate it should have a third full or partially zoomed ratio. Switching speed depends on what you are comparing it to. I think no two boxes are indentical in color. In the Channel List you can set it to skip a channel. I don't have a DTA809. All these boxes have their pluses and minuses. Do you presently have an exterior antenna ?
post #97 of 104
Does the partial zoom only letterbox 16:9 and not letterbox + pinstripe 4:3? Thsts really annoying Does it also take going through 5 menu to change? The channel switching is slow compared to analog. I have an internal antenna and can't change that. You're right about the channel skipping method.
post #98 of 104
Hit the menu button, get the channel line up (screen that shows station, what's showing, what's coming up) just to the right of the channel numbers it says 'Stored'. Using the center 4 way rocker on the remote scroll down to the station you want to delete, move to left to high-light 'Stored', hit the center button, and that item changes to 'Skip'.
I personally like the DTA 809 better with the analog pass through.
post #99 of 104
Originally Posted by Doc Sief View Post
... I personally like the DTA 809 better with the analog pass through.
The DTA800B1 also has analog pass through.
post #100 of 104
Originally Posted by DTV Reviewer View Post
I see on the approved government list the RCA DTA800B1L and DTA809 listed. Does anyone have any initial information on these units - differences from the current DTA800B1 model?
Our local Walmart stores (North Texas area) just received fresh shipment of RCA DTA800B1L which has been out-of-stock of 3 months. The S/N label is different from before and it included the manufacture date (February 2009) on the bottom of the converter box. They also put a "DTA800B1/DTA800B1L" sticker on the manual to cover up whatever the model number was on there. Don't know what has been changed on DTA800B1L from DTA800B1.
The box is manufactured by AVC Multimedia at Markham, Ontario L3R 1E3. The price is $49.87.
post #101 of 104
I picked up a DTA800B1 at Wal-Mart for $49.87. It was Mfg. in Jan. 2013. It has the code BE3.
AVC Multimedia, Markham, Ontario -- Made in China
The bar code on the box is 0-62118-48003-7
My LCD flatscreen TV has only one 75ohm input and only one RCA input (this is, Yellow-Red-White), which are both already being used.
I wanted to use the VCR to watch OTA channels, so I needed a DTV Converter box.
So far no complaints, except that I would prefer the display that comes up each time you change the channel, to be see-thru, or, for the display to go away much quicker, on it's own.
Picture and sound is good.
I didn't want to spend big bucks on a DVR/VCR with tuner.....
post #102 of 104
Surf through the menus as some boxes have settings for those features.
post #103 of 104
Doesn't that box have a guide of some sort?
If so, how is it?
Can you add single channels manually, or does the box need to be re-scanned?
post #104 of 104
If so, how is it?
The RCA box shows what's on now, but I can't find a guide on the box for programs coming up later.
The B1 model does indeed allow you to a channel "add" scan vs. a complete re-scan.
