Hi,
I am trying to setup my first home theater in my apartment. I have researched and found so many options that my mind is boggled, so I decided to go the other way. List down my requirements. Here is what I want to do:
Home theater needs to have excellent input connection. I plan to connect all these:
- PC DVI to HDMI input
- PC Optical out to Optical In
- Cable box Component out to component in
- Xbox to Component in (maybe get a HD converter?)
- DVD play to component in. I have an old DVD player but I might end up upgrading to an upconverting player or Blu Ray player
- So essentially all components connect to the home theater and then only video output goes to TV.
Here is another problem. I have been researching virtual surround, 5.1, 7.1, etc. and I believe as my apartment stands I need as minimal wires as possible or none at all.
so question is
- What is a good receiver?
- Is 2.1 or virtual surround systems available to meet my needs along with good audio
- Are wireless 5.1/7.1 systems/speakers available?
Thanks a lot for your help and recommendations.
so question is
