AVS › AVS Forum › Video Components › Home Theater Computers › "Official" PowerDVD Ultra 8 thread
post #1 of 2309
This thread is dedicated to the new version of PDVD Ultra
Works:
- All my BD ISO's all work, no stuttering on my G35 at all (MPEG2, MPEG4-AVC, VC1)
- All HD MPEG-2's (e.g. from Tivo S3/HD TTG) all work great
- HD Picture quality seems slightly improved actually, a little more detail/depth, and the color seems slightly better
- SD Picture quality seems significantly improved - SD DVD's look a lot better
- AVC-HD (e.g. from Sony HD video camera) works great
Not working:
- HDMI audio is a bit of a joke, no different than before if you want multi-channel HD audio (still sends 5.1 channels for 2.0 channel sources with 3 or 4 blank channels, for example)
- Crashes if you set to HDMI and DD/DTS passthrough (no matter SD or HD source)
Basically, PDVD8 is like the production version of PDVD 7 beta. Everything works like it should have with PDVD 7. Nothing particularly new, but nothing seems broken either.
(My configuration - HA off, Weave, HDMI Audio/PCM, Best picture quality, everything else default. C2D 2.66, 2GB, G35 at 1080/60p.)
Specific BD disks that seem not to work:
- Across the Universe
FAQ
- PDVD 8 only supports BluRay, no HD-DVD
- PDVD 8 peacefully co-exists with PDVD 7, including the 3319a/3370 toggle
- Doesn't support HDD playback using directory trees (only ISO mounting using DaemonTools)
- DTS-MA/HD support included now
post #2 of 2309
Is this a free update? If not, then Cyberlink should give me a free upgrade path to 8 since I purchased 7 just 3 days ago.
post #3 of 2309
What is the status of HD DVD disk playback? in this version.
Playback of HD DVD via ISO'S ?
Is 8 for BD only?
post #4 of 2309
Anyone noticed whether CPU usage has increased, decreased or no change with version 8 over 7?
Peter
post #5 of 2309
Peter
I've turned off HA (which barely works with the G35 anyway), and CPU usage is reasonable (~60%) with HD audio tracks. So it seems improved.
post #6 of 2309
Is 8 for BD only?
BD only
post #7 of 2309
All my BDs work as well except Across the Universe. Menus dont work and it will not play.
post #8 of 2309
Originally Posted by AbMagFab View Post
BD only
The most expensive version is slated to have HDDVD playback
post #9 of 2309
Edited first post:
- SD DVD picture quality is significantly improved, on par with other players
- AVC-HD works great (set to Weave)
- HDMI + DD/DTS pass through always crashes it instantly (HD, SD, anything)
post #10 of 2309
No mention of it in the version comparison. http://www.cyberlink.com/multi/produ...are_1_ENU.html
Do you have a link to something that says otherwise?
post #11 of 2309
There was some post somewhere that said they were going to have an add-on later this year with HD DVD, and I think they implication was also adding DTS-HD.
post #12 of 2309
DTS-HD is listed as supported in the chart I linked. I won't hold my breath for the add-on.
post #13 of 2309
Well I figured out why my BDs werent working... when I have D3DOverrider set to 'Force Triple Buffering' in DX9, PDVD8 doesnt like it and gave Internal Error when trying to play any BDs, so when it's disabled BDs work fine.
And yes, it decodes the full DTS-HD Master Audio in 7.1 channels. Well done Cyberlink
Even when I have PDVD set to 6 channels (I'm only 5.1), in Information it still says DTS-HD MA 7.1 on New Line discs
I'm so glad Cyberlink sorted out the activation stuff, they even replied to my inquiry after it was fixed saying they had rectified their servers.
Can't find anything to fault sofar, looks like my $100 was well spent
post #14 of 2309
A couple of years ago, I bought PDVD 6.0 a couple of weeks before PDVD 7.0 was released and they gave me a free upgrade to 7.0. YMMV.
I'm still waiting on HDMI soundcards other than the G35 motherboard... I'm wanting to consolidate everything into my HTPC, but I'm still using a standalone BD player for the lossless audio movies.
post #15 of 2309
This rumor got started by a very bad article about PowerDVD 8 that contradicted itself. It is not reliable at all, and it even contradicted a screenshot of features that they themselves published in the same article. I wouldn't have any trust in that statement. Why on earth would they bring HD-DVD LATER ON (as they said)? The person who wrote that article said they've used PowerDVD "for years" or something... it didn't seem like it. It was poorly written and factually VERY inaccurate.
post #16 of 2309
Hi, I was wondering if there was any other Canucks who had bought this yet. When I go to the checkout and select Canadian $'s,it says its $67 CAD, but if you do a currency conversion it should less than $61 CAD? I was wondering what it appears as on a credit card. Thnx
post #17 of 2309
I wonder what version number we'll get up to before they FINALLY fix the Across the Universe problem
post #18 of 2309
Does anyone know if you can play Blu-Rays or HD-DVDs with the trial version?
post #19 of 2309
No on both for the trial. The registered full version will only play BluRay. No HD DVD support.
post #20 of 2309
You can't play Blu-Ray disks with the trial version, you need the Ultra upgrade/retail version.
HD DVD not supported in any version of PDVD8, use latest PDVD 7.3 for that.
EDIT: too slow
post #21 of 2309
Well that sucks. Looks like it would be a downgrade from 7.3.3730 Ultra if it can't even play HD-DVDs. I'm actually really happy with my current version, but the OP saying that SD quality is greatly improved (and possibly HD) got me interested.
The new Remix feature looks useless. The Collect and Connect features look alright, but they don't exactly get me excited. I'm guessing all of these features add significant bloat.
Can anyone confirm that there are decent resizing features for Blu-Ray? I would like to zoom in some on 2.35:1 Blu-Ray/HD-DVD movies, but 7.3 doesn't allow it.
post #22 of 2309
What version are you guys buying? Are you paying the full 99.99$ for the Ultra-Version or are you buying the Upgrade from Ultra 7 which costs 59.99$. I would go for the upgrade but only if I could keep working with PowerDVD 7 Ultra as well. I've still got a lot of HD DVDs.
post #23 of 2309
I wonder if having version 7 and 8 installed simultaneously causes any codec conflicts.
post #24 of 2309
I planned to run some tests this weekend to see if the version 8 codecs can be used in 7.3. If I do get the time to try it, I'll post my results.
post #25 of 2309
Works:
Not working:
So no hard-drive playback I presume???
post #26 of 2309
Originally Posted by Favelle View Post
So no hard-drice playback I presume???
When you said plays blu-ray iso's does this mean you can play off the hard drive via mounting an iso to a virtual drive?
post #27 of 2309
As I still want to play my back catalogue HD-DVDs I contacted Cyberlink's support regarding this issue. Here is there reply...
Thank you for contacting CyberLink Online Support.
We understand your concern related with PowerDVD software.
PowerDVD 8 can playback any type of disk. Namely CD, DVD, HD-DVD and Blu-Ray disks.
Moreover, you can install PowerDVD 7.3 and PowerDVD 8.0 on the computer at a time.
Hope this helps.
Keith
post #28 of 2309
Works:
Not working:
But it still downconverts the audio via analog out to 16/48, thats a shame!
The annoying aliasing effect with 8600 GTS is still there too.
CL is one of the worst software companies I have ever seen, shame on these morons.
post #29 of 2309
Can you actually hear an improvement with DTS-HD MA tracks?
post #30 of 2309
Yes, the sound is remarkable improved with PDVD8. Heard Queen Live (only DTS-HD though) yesterday on PDVD7 and PDVD8 and PDVD8 really sounds a lot better, richer, wider. Just imagine, how it would sound with real 24/96 output!!!
Also heard Eragon with DTS-HD MA track and thats really the first time I was so much impressed by sound from PDVD that i got emotionally touched.
As a side note: I also own Arcsofts TMT with real 24/96 output and it sounds much worse than PDVD8!!!
Maybe 24/96 is not a big difference to what we can already get out of PDVD!?
