AVS › AVS Forum › Video Components › Home Theater Computers › Hauppauge WinTV HD PVR (H.264) screenshot
Hauppauge WinTV HD PVR (H.264) screenshot - Page 60
post #1771 of 5194
I have 2.53 Gig P4 with a Raden HD 3850 video card and it works just fine.
My HD-PVR is connected to the comcast cable box and I run ~50' of usb 2.0 wire through the drywall upstairs to the computer. No issues. (there are 3separate 15' usb cables and 3 powered usb hubs. I also have usb cameras connected to the hubs and it all works. Captures are fine and the video quality is great. I also have 4 other computers connected to the network and I can play the h.264 .ts files on the other 4 computer from the hard drive in my main computer.
post #1772 of 5194
Originally Posted by PhoenixCoyote View Post
The BD option won't appear if and when you install a BD drive. I emailed Arcsoft support a while back regarding the lack of Blu-Ray option in the version of TME that came with the HD PVR. They replied back saying it's an OEM version without the Blu-Ray playback/burning options enabled. To get the BD option you'll need to purchase the full version which is what I ended up doing.
Somehow missed this when you originally posted it. Obviously, this isn't the news I wanted to hear. Have you tried using the full version to burn to Blu-ray discs? Successful I presume?
post #1773 of 5194
I'm looking to buy a HD PVR and I need it pretty fast. If anyone is interested in selling their HD PVR, please PM me.
post #1774 of 5194
Here are some updated results of trying different encoding rates and different recording lengths and the video stutter/shake . . .
My computer is:
Dell Dimension E510 Series Intel® Pentium® 4 Processor 630 w/HT Technology (3.0GHz,800FSB); 1GB Dual Channel DDR2 SDRAM at 533MHz (2x512M); 256MB PCI Express™ x16 (DVI/VGA/TV-out) ATI Radeon X600 SE HyperMemory; Windows® XP Media Center 2005 Edition; 16X CD/DVD burner (DVD+/-RW) w/double layer write capability
Recall I seemed to have the video stutter/shake for 90 minute and 2 hours recordings at 9M encoding rate, but was okay for 5M.
Now I tried the following:
90 minutes recorded at 9M - TS file size 6.2G - burned to 8.5G AVCHD disc - video stutter on PS3 playback
90 minutes recorded at 5M - TS file size 3.6G - burned to 4.7G AVCHD disc - PS3 playback okay
30 minutes recorded at 13.5M - TS file size 3.1G - burned to 4.7G AVCHD disc - video stutter on PS3 playback
30 minutes recorded at 9.0M - TS file size 2.1G - burned to 4.7G AVCHD disc - PS3 playback okay
Now I am trying a 90 minute recording at 7.5M encoding . . .
So, whereas I saw the PS3 playback video stutter on 9M encoded recording, I did not see that for a 30 minute recording? For me at least, there *seems* to be a difference depending on the recording length, since the 30 minute 9M encoded works okay, but the 90 minute 9M encoded did not.
Maybe this is a result of limitations of the computer I am using . . . any thoughts or guidance are greatly appreciated!
Update: Recording 90 minutes with 7.5M encoded works well via AVCHD disc on the PS3. Now am trying a 2 hour recording at 8M encoding (average) with a 12M encoding (peak).
post #1775 of 5194
Is there a relatively easy way to do this? The "hack" of m2ts to m2t is simple and works perfectly for the PS3 (thanks for that post) but from what I have read on this thread getting an HD stream to the XBOX 360 is much more complicated. Is there something easier than demuxing and remuxing (using programs like megui that themselves seem to be quite involved in at least the set up)? It would be great if one file type that could easily be generated worked with both consoles but that is likely a bridge too far.
BTW, my rev C1 has worked very well, capturing in multiple lengths and bitrates, burning to DVD and streaming to the PS3. The only problems have been interference on the passthrough, slightly softer recoding and the oft mentioned lack of current 5.1 and good editing software.
Many thanks.
post #1776 of 5194
Many thanks.
i don't know about streaming to the 360 but it plays mp4 files perfecly...if you use the Hauppauge converter (not Arcsoft) they are created rather quickly.
post #1777 of 5194
Yes, if the MP4 Converter software works for you, its an easy, one step process. It just doesn't work for everybody and ends up crashing. For me, occasionally it works, but most of the time doesn't.
As for streaming to the 360, it works great with TVersity. Just remember to set TVersity up so the files don't get reencoded on the fly (if that would even work).
post #1778 of 5194
Well, the one remaining HD-PVR, the one I returned on RMA and came back with a heat sink and fan just locked up on me while watching live TV in Sage.
There is obviously something else wrong with these things than can be solved with a hacked together cooling solution. I'm now thinking about calling Hauppage in the morning and arranging for a refund on all 3 devices.
Maybe by the end of the year they will have this all sorted out and the things are reliable enough to use with Sage.
post #1779 of 5194
Wonder if the power supply is up to supplying the extra power to that chip that's overheating, since I have the old chip, and mine only locked up once, but it was 85f in the house. Since I turned the temp down to 80 during day, no problems.
It does occasionally lock up if I try to send IR commands to my FTA receiver to fast (channel surfing), but if I wait a minute between changes, its ok.
post #1780 of 5194
[quote=sleonard;14257141]... with a hacked together cooling solution./QUOTE]
Yep, I'll agree that simply sticking in a 40mm fan along the side of the circuit board fastened with double-sided tape against the bottom of the case, as Hauppauge did, isn't much of an elegant solution.
This thing is going to go through a bunch of revisions...
post #1781 of 5194
I believed there must be something wrong with certain production batch of the chip manufacturer. My C1 HD PVR has not experienced any problem on recording or playing back at 1080i/~10Mbps with consecutive recording time up to 10 hours. There were no stuttering in recording with/without preview or playing back using TMT/MPC or PCH A-100. The case is warm but not hot when left on (recording or not) for more than 48 hours.
Maybe, I'm just a lucky owner, *so far*...
post #1782 of 5194
It is kinda hard to believe they just stuck a heatsink and fan in a box that's sealed virtually airtight.. Actually, not so hard to believe from a money standpoint I guess.
I know noone should pay $250 for an item that needs modification to it to get it working reliably, that's a given.. But for the more adventurous out there, I'd strongly recommend just taking the lid off the box and see how that works for you before giving up on it. It's got a 2 year warranty and I'm sure they'll have it rectified by then - might as well get to use it in the meantime.
post #1783 of 5194
on two different pc's now when i burn disks TM just locks up...no error message it just sits there at 20-49%. i've tried reinstalling, different files, restarting and even dl'ed the full version trial and same result...help please. 1 pc is athlon 2.0 with 2gb ram and the other is a dual core 2.2 with 2gb ram and a ready boost drive for another 3gb of ram.
post #1784 of 5194
I agree. I also have an early C1 (delivered 6/5) that has worked well recording over 70GB of movies. No stuttering or skips in playback streamed to a PS3 and PQ is as good as source at 13.5 mbps capture rate. Barely gets warm if set on it's side. QA was inadequate on some units. Now if they would only get the 5.1 audio working.
post #1785 of 5194
For what it's worth, here is my rough matrix of recording length vs. encoding rate for my set up (P4 3GHz PC) and using AVCHD disc burning to port over to the PS3 . . . I get video stutter/shaking on PS3 playback at rates above these (that is, these work okay for me):
recording length / encoding rate (ave)
30 minutes / 9.0M
90 minutes / 7.5M
120 minutes / 5.0M
post #1786 of 5194
I just received my C2 and I haven't had any issues with it whatsoever. In fact, I think I figured out what was wrong with trying to use Ulead video studio. Not surprisingly, they don't include AC-3 codecs in their free demo, which of course is what the HD-PVR is using for its audio. That would explain why the audio plays fine in PowerDVD, but not in Ulead. After speaking with one of their techs, I went ahead and ordered a copy of the retail software through Amazon. Anyway, all of my recordings are fine, and I've even had it on for days at a time without overheating. Even if I did need to reboot it, which I haven't yet, I always could as I'm using the thing simply to dump the contents of my HD Tivo (i.e. none of my recordings are live).
I will say that there was a considerable delay, and Hauppauge slipped on their delivery date to Amazon (and thus to me), which is why I had an order placed May 8 that wound up taking 2 months to satisfy. I'm guessing they must have had issues with entire production revs or batches, like some people have said, resulting in my delay. Oh well, I guess sometimes the best things ARE worth waiting for.
post #1787 of 5194
Originally Posted by glpatz View Post
I have been playing with my HD-PVR for a couple weeks now. First thing I noticed was files transfered from my HR20 at the highest bit setting were to large also. My wife and I came up with a somewhat rough calculation for setting the bits to highest optimal setting for a 4.7 and 8.5 GB DVD. Grant you it was somewhat inaccurate my first try, it did give me a baseline to start with. After 4 trys I managed to calculate a bit setting at 10.6 which produced a 1Hour and 40 minute movie to fit on a 8.5 GB DVD-DL. I would assume this would work for any length of program. I have not tried it a second time with a different length program yet. That is why I am jumping in here now. When I played the disk on my Blue Ray Player the quality was excellant until it started to pixelize about every 20 or 30 seconds. I did burn it with TME. Funny thing is that the transfer was flawless through the the preview window. I have also played it on Cyberlink PowerDVD and the video quality is flawless except for the delayed audo stream it produces. So I know it is not the file itself. I can only assume the problem occured from the TMR software. It could possibly be Vista. I cannot get the transferred file to play or edit TME also. I have not had time to read back in prior posts to see if anyone else has had this occur (pixelization).
If anyone else would like to play with the calculation we came up with, here it is:
D = 8.5GB = appx 66300 or D = 4.7GB = appx 36660
M = Program length in minutes
M X 60 seconds = S
D devided by S = MBit/sec setting - .99 = correct adjusted MBit/sec setting
I came up with the .99 error from just tweaking the MBit/sec setting down until I was able to get the file to 8.45GB. I am curious to see if it will work again with another size file, but have been trying other editing apps with the AVCHD files with little success. Has anyone had better luck with other burning apps with these files? So far TME is not performing for me except just the basic transfer from the DVR to my PC.
One other note. Does anbody have any idea why TME calulates there is 461.36KB used on a 8.5GB blank disc? Sorry if I am hashing over issues that have been addressed earlier in this post, my opinion is that ArcSoft TME is not ready for prime time.
thanks for the effort!
post #1788 of 5194
Originally Posted by jatoghia View Post
I just received my C2 and I haven't had any issues with it whatsoever. In fact, I think I figured out what was wrong with trying to use Ulead video studio. Not surprisingly, they don't include AC-3 codecs in their free demo, which of course is what the HD-PVR is using for its audio. ...
Just to try to keep the record straight and clear, at this time the audio as recorded by the HDPVR (i.e. in the original TS file) is AAC. It is converted to AC3 by the bundled Total Media Studio or by other post-processing sw.
post #1789 of 5194
What version of VideoStudio are you referring to? I'm assuming that you still can't import .ts files for editing.
post #1790 of 5194
This is what I would like to do:
Take the programming that I have already recorded off of my DirecTV DVR with the Hauppauge HD PVR. Take the files created by the HD PVR and using some program (Pinnacle Studio Plus 11.0??) create HD video that is playable on a HD-DVD player using standard DVD+/-R media (single or double layer). Would the HD PVR work well in this situation? What software would anybody suggest for converting the supplied AVCHD file created by the HD PVR into a file that is playable on a HD-DVD player? I did some research and it looked like Pinnacle Studio Plus was capable of this in version 11 but no longer with the new version 12 (since HD-DVD is dead, it looks like they dropped support for it). I am open to suggestions on everything.
Also, has the DD surround sound issue been resolved yet, or is the HD PVR still only working with stereo audio?
Thanks for all your help guys!!!
post #1791 of 5194
I have converted a few captures to BD ISOs, but IIRC the authoring app can convert and burn to HD DVD. My process is using TMPGEnc Xpress Pro 4.5 to convert the TS file from the PVR into a blu-ray formatted MPEG file. From there I import into Ulead Videostudio Plus 11.5 and create a BR iso without a menu. TMPGEnc creates an excellent MPEG that is compliant with BR/HD DVD spec, so Ulead shouldn't reencode the file again. IQ has been excellent for me with these two pgms.
Again I havent tried an HD DVD iso but I think i remember profiles for it.
Oh, and we're still waiting for DD5.1
post #1792 of 5194
Well, the demo was for Videostudio Version 11. The one you actually need to author AVCHD is 11.5+. Yes, it could open the .TS files I created with ArcSoft. Unfortunately, it couldn't open the audio. Even more bizarre, when I ran the Arcsoft program that was supposed to create a "compatible" mp4 file, Videostudio couldn't read it.
post #1793 of 5194
Oops. You are correct. Strangely, the conversion to MP4 files also results in a file in which the audio and video are completely out of synch.
post #1794 of 5194
The HD-PVR allows you to save a TS file to your PC, and then it's up to you to do with it what you want. I have burned my TS files to a standard DVD (both 4.7GB and 8.5GB) and had it play in a standard DVD player successfully.
If it plays there, then I'm sure it'll play on a HD-DVD player... in SD.
Now if you want to burn a AVCHD DVD, you can do that too. I've done that and it played ok on my PS3, but I don't have a HD-DVD player. I guess that you'll have to look into whether your model recognizes AVCHD disks.
Not yet.
post #1795 of 5194
Originally Posted by RAVEN56706 View Post
has anyone used this with the directv hd dvrs?
Yes: I did use my original unit (before the RMA) with my DirecTV HR20-700 DVR, but two problems with using it with a DVR:
1. There is no way to control which of the two active tuners will send out the video; and
2. If using both tuners and it is time to record another show, an onscreen announcement will come on about that fact and allowing you to cancel the next recording.
With that experience, and now having my 2nd unit (and to answer your earlier question, yes the newer units have a C2 sticker on the bottom), I obtained a HD DirecTV Receiver model HR20-100 which is now dedicated to the Hauppauge HD-PVR. Yes, I spend an extra $4.99/month for activating this receiver (I got a supervisor to give it to me for free and waive the $99 fee), but it is worth it to have the ability to HD-PVR and use my dual tuner DVR unit for my other needs...
If you are manually playing back Giants playoff games that are already on your D* DVR, you should have none of the aforementioned problems. A further discussion about the HD-PVR and football:
http://forums.tenyardtorrents.com/vi...d=94479#p94479
Personally: I prefer to remember the Giants in the 2nd picture:
post #1796 of 5194
For the HDPVR to be minimally useful to me operationally (that is, PQ aside) my requirements were
1. It must run continuously for weeks
2. I must be able to capture from it unattended, with my own software, since it tunes the cable box, coordinates other capture devices, and controls the waking/hibernated state of my HTPC as needed for my capture schedule
3. I must be able to trim the ends and chop the remainder into DVD5-sized chunks for burning
4. I must be able to play back on PS3 or PC
5. All of the above must be free of tedious interaction and long-running processes (e.g. re-encodes)
It's taken a fair amount of effort, but as of this week, a bit over a month after effective delivery, I can check off all five points without any serious qualifications. Whew! Some details for each:
1. Run all the time. My first unit, delivered June 2, was a fast-fryer, I returned it overnight and got another rev C1 unit on the morning of June 5. After verifying that it worked, I modified it for the heat problem - assuming that as so many failed, "working" ones were probably marginal and would probably be ruined by continuous use. I opened the box and stuck Thermaltake CL-C0025 heatsinks on the processor and ADC chips. I popped out the insert in the top and made a substitute lid, cutting the lid from a RS project box to fit and to hold a 40mm fan. I cut one end off a smaller 2" project box, lined it with sound absorber, and mounted it inverted over the fan to protect it and quiet it. I made a Y-cable to insert in front of the power cable input to the box, with the extra lead feeding the fan. The HDPVR is rated at 10W drawn and the powr supply at 15W supplied, so it should not be any issue to take off 1W for the fan. Except for one day when I was re-arranging it, and a few 5 to 10 minute intervals, my HDPVR has been on continuously since June 7, with no indication of any heat-related issues.
2. Capture. Although it presents as a DirectShow Video Capture source, the HDPVR does not behave as other such do - it requires a bunch of upstream setup to work. Using some clues from other posters here, I was able to understrand how to set up a capture graph to work with the HDPVR. Then it was only a few hours work to have an initial working mod to my capture sw, to use an externally defined graph as an alternative "capture strategy". Given that, all my scheduling and PC ops management worked with it. Every 10 days or so I build a schedule (that's another app, never mind!) and load it into my capture sw, and it runs the PC from there. So far I have captured just short of 500GB with my sw from the HDPVR, that is a bit more than 40 full-length features that I will be able to enjoy later on my schedule, not on a some network's. The capture process uses about 1% of the CPU, and a pretty low rate of IO for a modern disk drive, so the PC is generally available for anything I might want to do while capturing from HDPVR.
3. Trim, chop, burn. When I'm not ready to watch something right away, I may burn it to DVD5 to make space on hard disc, and I want to burn the original TS's, not a derived format, expecting that to be a better starting point for any processing I might decide to do later when I'm ready to watch it. I use DVD5 for that because it is still the most cost-effective, though the margin has fallen to the neighborhood of 2x cheaper than hard disk. I don't do commercial material with the HDPVR, so I don't have that problem to struggle with, but I almost always need to trim some junk from the start or end of a program. I found that (with, and only with, CoreAVC Pro installed) TS Packet Editor (TSPE) could locate trim points exactly, even though it would apply them inaccurately if you then asked it to cut the file. With some small changes to own trimmer/chopper sw I made it easier to use the data as it appears in TSPE. Now when I want to process some capture files, I select a bunch of them in my trimmer/chopper (grid display), then open each file in turn in TSPE, locate the start and end trim points, and paste that into my own GUI. When they are all set up, I click "Go" and go do something else while the files are processed. Then I can burn the chunks to DVD5 for longer-term timeshifting - selecting multiple "tail" chunks when needed to ~fill a disc. And, since the (non-working, so far) MP4 Creator won't accept any TSs that have been modified (e.g. trimmed) I also keep the parts trimmed off the front as part0 - against the possibility that MP4C may come to a working version and I might want to reconstruct the files for it. BTW, each of the chunks also each plays fine in Arscoft.
4. Playback. PC playback is fine for me on 3GHz E8400, Nvidia 8800GT; capture with Arcsoft used about 50% of CPU but playback is in single digits, and although PC playback always seems to have some extra jitter, I find it completely acceptable. But the PS3 is a better player and can be available when the PC is too busy with other chores. After a bit of flailing, I found that the only way I could get to the PS3 using the bundled sw was using Arcsoft "burn to avchd" (Total Media Studio, TMS). Either pre-chopped or whole files come out OK for me, and I can either burn to DVD or stage the files from the STREAM directory (renamed from 00000.m2ts to Whatever.m2t) for streaming by TVersity. But this was a tedious process, a dismal failure by requirement 5. More recently, following up from some clues posted by ScottTX, I have been able to work out a batchable remux process using a graph to extract the audio and convert it to AC3 and then TSMuxer to remux the video stream with the converted audio. I wrote a GUI to automate this. With this tool, which I call H1R (HDPVR V1 Reworker) I can select a list of files, press go, and come back later having them all refomatted, optionally trimmed, optionally chopped, staged in the media library folder on my server running TVersity, and ready to play back on the PS3. With these files played on the PS3, Pause/Play works fine, and frame advance, and at least brief FF/FR generally work OK.
5. No tedium. Whew! With H1R I can finally do all my essential steps with no tedious sit-in-front-of-it, come-back-and-answer-it, now-do-the-next-one aggravation. When they release 5.1, AC3 support a lot of this will change. But for me, HDPVR Rev 1 is now fully domesticated.
Tools.
My requirements would not be met if I was limited to the bundled sw, nor, as far as I can tell from reading the experiences of other users here, would other commercial sw do it for me. But, I've been a professional sw developer for 30 years, and I'm now semi-retired (while still young enough to enjoy it!) So, both for fun and for filling the gaps, I routinely crank up the IDE and work on little (or sometimes not-so-little) homebrew software. I have done only a little stream-level work in AV; I did make some contributions to tsremuxer under a different nom, but those were mostly performance-technical in nature. So I'm really happy to be able to use tsmuxer (not! the tool I contributed to) in my process.
Tools by others:
TSPE - you can download that (from videohelp, I think) the developer is not working on it any more
TSMuxer - another free download, easily found
CoreAVC Pro - costs about $15, I am glad I bought it
Haali Media Splitter - included in CoreAVC, I think lot's of other ways to get it
My own tools
Capture sw - my main progam is too complex to release, but I made a simplified version (RoboCapLE) and got good feedback in a small, closed beta test. That went well enough that if there is interest I could release it as a "public beta". I expect it will never be anything other than "beta", but I like the simplified version enough that when I start some different processes with my second unit (e.g. recovering DVHS tapes) it's the tool I'm going to use.
Chopping sw - too complex to release - I can't afford the time to explain how it works. I've considered reworking/simplifying it for release, but that's not high on my (long) TODO list.
Reformat sw - H1R is pretty simple (well, the hard parts are component classes re-used from my other tools), and I could buff it up a little and make it available as an open beta if there is interest. It does require you to go get Haali Media Splitter and tsmuxer.
Bundled tools
I just use the HDPVR driver, and the Arcsoft playback app. The rest is - not ready yet, IMO/IME.
Well, that's too long of a post. But I was just SO HAPPY to have checked off 4 & 5
-tom-
post #1797 of 5194
Nice work!
Mine is now running 24/7 in the upstairs guest bedroom. I decided against the X-10 remote shutoff.
It seems to be fine, but still needs more testing. I have not modified the C2 in any way.
I'll have a picture of my setup later this weekend.
post #1798 of 5194
While we wait:
I find that many sources encode their analog stereo track with Dolby ProLogic II. When playing my HD-PVR transcoding back through my AppleTV and my Panny Home Theater set to Dolby ProLogic II, I get an excellent surround sound experience.
I would need a test clip to get a better A/B comparison, but it is hard to distinguish from when I play the same clip on my DirecTV HD-DVR through the Panny HT in Dolby Digital AC3 5.1...
post #1799 of 5194
this is the answer i have been waiting for.....
post #1800 of 5194
the_tom, Thanks for the fine post. You are both a great writer and great technician. I'll be interested in seeing updates to your adventures.
