The thing is, if what you are trying to accomplish is to play stuff on the PS3, there are lots of suggestions on what works for folks, but you don't seem to be doing anything with them.
Instead, you seem to be repeating, "my wmv's from media converter don't work, and my MP4's from mp4 creator don't work, what should I do?" Having something play on the PC has no predictive value for PS3 playback; in fact my files that play on PS3 don't play on my PC.If you want to be successful, what I suggest you should do is stop trying to use those approaches and tools that aren't working. Instead, try some of the suggestions and tips already in this thread; here are five posts related to preparing files for non-PC playback from the past few pages of this thread, the first two of which were in direct response to your inquiries, and which your latest posts seem to indicate you have not followed up on:
http://www.avsforum.com/avs-vb/showt...5#post14272215
http://www.avsforum.com/avs-vb/showt...1#post14244461
http://www.avsforum.com/avs-vb/showt...5#post14276315
http://www.avsforum.com/avs-vb/showt...9#post14272769
http://www.avsforum.com/avs-vb/showt...2#post14237152
I wish you success, really. We pretty much all agree that the things you say aren't working for you, don't work. Maybe it's time to try some of these other things.
I just meant that it's not necessary to reencode at a higher bitrate than the original file.
