Originally Posted by Kilyin
ARogan:
I have successfully setup a recording graph thanks to your instructions and those posted here.
I have uninstalled all of Arcsoft's garbage software because frankly, I hate it, and I was never able to register it successfully anyway.
I did copy the Arcsoft MPEG-2 Demuxer and manually regsvr32'd it. Then I tried following your directions to create a preview graph to watch streaming TV but all I got was sound. I went back over the instructions and repeated the process until I was ready to break things, but always the same end result... sound only. What do you think could be the problem?
Also, even though I created the pins and saved the graph, whenever I close the graph and reopen it, I have to recreate the pins and reconnect the last few filters in the chain.
ARogan:
Out of curiosity, which audio and video encoders are you using after the Arcsoft Mpeg-2 Demuxer? I never had much luck with anything other than the Arcsoft Video Decoder when using the Arcsoft Mpeg-2 Demuxer?
Edit: It's also known that the Arcsoft Mpeg-2 demuxer won't keep the mapping of the pins, you have to do it manually every time you open the graph, or so far no one that I know of has been able to do it. There is a post by vladd, don't know the exact link, he uploaded a program that uses a different mpeg-demuxer and will actually play the hauppauge feed on the PC, you could try it out.
. Thanks for the help!
