Thanks for info, I will set mine to variable.
Originally Posted by rebkell
I actually use Variable Peak, and max out both Average and Peak in the Mbps settings. I've not had any problems with it and been very satisfied with the results. The problems with editing are normally associated with selecting the various GOP settings, which can only be gotten to via the graphedit program, Simple GOP seems to be the recommended setting if you intend to edit.
