The article being refered to is on the newstand so you won't find a URL on the internet.
I read the review and was pretty impressed with what that had to say about the Dynaudio speaker group. I've also read some good reviews on the B&W line of speakers.
I'd use
www.ecoustics.com to search for articles. Here are a couple good links for the B&W line. Depending on budget, I'd also look at the CDM-xNT line. Might be easier on the wallet. As I understand it, it borrows some of the nautilus design.
http://www.stereophile.com/showarchives.cgi?168http://www.hifichoice.co.uk/review_read.asp?ID=766http://www.hifichoice.co.uk/review_read.asp?ID=879
When you get to this level of sound quality I'd say the choice is pretty much a matter of personal preference. The B&W and Dynaudio both seem to provide very good sound. I'd concern myself more with the personality of the speaker and additionally the characteristics of the hardware you're planning on using to drive the speakers. System matching will make a big difference in the final sound comming out of these guys.
