AVS › AVS Forum › Audio › Receivers, Amps, and Processors › i need receiver range $400 $600 Through 1 HDMI video and audio to run
post #1 of 2
This is my setup 5.1
JBL CST55 FLOOR STANDING SPEAKERS
JBL CSC55 Center Channel Loudspeaker
JBL CS600BG Satellite Speakers
1080P TV, PS3
i watch loot of movies, watch loots of 1080i HD channels shows, movies,sport, etc.... and sometime play music
i need a receiver that is able to run through HDMI cable audio and video i dont want separate cables for audio to run, i like faroudja and of course all THX,DTS and everything else what would be the best choice. i dont know much of receivers all i wrote is something that i learned reading and yes some upconversion at leat 1080i becouse probably 1080p/24 are just way expensive.
Please advise
post #2 of 2
Really what exactly is it that you like about THX?
The truth is that you can fall into everyone’s favorite marketing trap and spend thousands on a receiver or you can just buy a receiver that works well and has everything you need.
The Yamaha RX-V663 is a good choice at $400 if you phone in your order to jr.com. It will do everything you need all over a single HDMI cable. Don’t believe the hype about upscaling in a receiver. Up conversion is all you really need.
If you can wait a month or so then there are some Pioneer VSX-1018TXH-K looks very tempting also.
There are also a few Sony receivers coming out that are at some hard to believe prices.
