Originally Posted by kiwin
Here are the steps I did:
The DTA box: RCA DTA-800B
Connect RCA DTA-800B composite video and audio output to ReplayTV input 1
On ReplayTV in "Menu" \\ "Setup" \\ "Network and Input Settings" \\
"Change IN 1":
choose "Satellite box"
choose "DISH Los Angeles" (or your metro area or DirecTV local seems to work - national will not give local stations)
Satellite Box brand": Other
On "available Code Sets" press the "Replay Zones" button.
change "Enable Fine Tuning" to "Yes"
Codeset: "0566" use the number keys on the remote to type the 4 numbers
Send Enter: yes
Minimum digits to send: 1
All the delays should be: 200ms
Change ANT/CATV should be changed to "Nothing Connected" (to prevent this new connection from have channels with 1000 added to them)
Then "keep all changes"
It will then download data for a few minutes.
On ReplayTV in "Menu" \\ "Setup" \\ "Add or Remove Channels"
make sure to delete the 100s of non-terrestrial channels so that only your local channels are displayed (and recorded)
Install the REPLAYTV IR Blaster cable and stick the transmitter right
over the DTA-800B IR Receiver. (Just to the left of the IR letters on the front panel
"Change IN 1":
Send Enter: yes
This is an AWESOME post!!!
I just have one very weird problem - ReplayTV (4040) is able to change to all channels except channel 30 - anybody has an idea?
I'm not knocking the Zenith, it's just for me PQ and the nice guide trumps a cruder menu and any possible slower operation. JMO
) and I got the same Blue Screen issue with it numerous times, even with 90% signal strength with the DigitalStream. The RCA box never did this.
