Originally Posted by boekjar
So would you now correct your list to:
RCA DTA-800B: works, allows subchannels over IRBlaster (negative is periodic audio loss, needing reboot)
DTX-9900 and 9950: work with 2000/3000, but not 5040, and no subchannels over IRBlaster
CM-7000: works, outputs in S-Video, allows subchannels over IRBlaster (with fine-tuning)
Zenith DTT 900: will only work with later replayTV models and requires some DVArchive AND WiRNS hacking to enable ".1" subchannels (negative is not usable with other subchannels? and not with 2000/3000 series)
DTVPal: (I don't know if there are updates to this one) coming out soon, may work with Echostar codes, no telling if subchannels will be accessible without hacking
In all cases, Program Guides do not work with subchannels without WiRNS. (Correct?)
Correction (since you stated that the DS boxes will not work with Replay 5040):
Digital Stream DTX-9950 works perfectly with Replay 5040 (aka: 5000 series)!......
uses code #7470 (any other codes will result in inferior performance).
