Hi all.
Just got my LG BH-200 (only 400 bucks!)
updated firmware to 3-14 version (worked fine)
set it to region free (worked fine)
and now i have a few questions for you people that have more experience with the unit.
1. I'm thinking of getting a new receiver that can take advantage of the HD audio it decodes. Whats a good receiver that you would recommend hooking up to the BH200? I'm trying not to spend much more than 500 bucks. I hear Onkyo is pretty good for the money.
2. I noticed that aside from playing video files, the usb port can be used as memory for when you play Blu-Ray movies. Does this only benefit 1.1 and 2.0 discs? Does it make any difference with 1.0 discs at all?
3. Thinking of hooking up a router to the back of it too. Can anyone verify which routers work with it?
