AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Cable TV sound and color problem. Please Help!
post #1 of 3
Hi, yesterday I bought a 47 inch Olevia to play PS3 on. The PS3 works great with HDMI. A problem has recently come to light that I cannot find anything about online. Here is the scenario. I turned on my tv to watch some television and the color was very blotchy and blurry, and there was no sound, just white noise. It was almost as if all I had to do was change the input or something. Funny thing is, it fixes itself after about 10 minutes of just sitting there. I know there is nothing wrong with the TV cause when I play the ps3 while hooked through HDMI, it works absolutely fine with no problems. It's just that when I switch to cable tv, there is no sound and the color is screwed. This is my first LCD screen, so I am pretty noobish when it comes to the settings and such. Can anyone help me out? Thank you very much.
post #2 of 3
What are you using for the tv connection. Type of box, cables, etc.
post #3 of 3
no box, just direct cable hooked into TV. The problem only lasts for about 5-10 minutes after turning on the tv. The ps3 looks fine on the spot, it's just a tv issue.
