AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Need help identifying LCD connector: 9-pin, 12mm
post #1 of 2
Hello everyone,
I recently purchased a mini-lcd screen and controller board. I asked about the input to the controller board before buying it, and the manufacturer said it was a standard AV input and I wouldn't have to buy or build anything custom.
Well, needless to say, when I got the device I quickly realized that my def of standard is different than theirs. The connector into the controller card is 9-pin and 12mm wide. According to the spec sheet the pins are:
video
videognd
nc
gnd
adj
gnd
gnd
E
E
I'm including a graphic of the spec sheet as well.
Does anyone have an idea of what type of connector I would have to get to connect to this display device?
Thank you so much for any help that you can provide!
Joe
post #2 of 2
bump
