Does anyone know when the Magnavox TB-100MG9 converter box with analog pass through will be available?
AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Magnavox TB-100MG9 availability
Featured Stories
AVS Top Picks
post #2 of 119
4/14/08 at 5:44pm
post #4 of 119
4/21/08 at 1:28pm
- dattier
- Trader Feedback: 0
- offline
- 2,358 Posts. Joined 3/2008
- Select All Posts By This User
Where would this Kmart be? It's not on kmart.com; sears.com has the Sylvania but the stores near me show only expected deliveries late next week and no current inventory of it.
post #6 of 119
4/22/08 at 9:50am
post #7 of 119
4/23/08 at 6:47am
post #8 of 119
4/23/08 at 7:47pm
- dattier
- offline
When I tried kmart.com's search function, it showed the Sylvania TB100MG9 only as a hit at sears.com. Of course, the actual K-Mart and Sears stores near me did not have any boxes at all. (Wal-Mart here has stacks and stacks of the TB100MW9.)
post #9 of 119
4/23/08 at 9:01pm
post #10 of 119
4/23/08 at 9:24pm
- satpro
- offline
- 1,574 Posts. Joined 8/2000
post #11 of 119
4/23/08 at 9:43pm
The G9? With passthru? Did it look like Manavox fixed the overheat problem? More ventS?
post #12 of 119
4/28/08 at 1:33pm
- BobOnTampaBay
- offline
- 33 Posts. Joined 12/2003
The box is now available. I got one yesterday. It was on Sears.com. It was listed as a Sylvania, however a Magnavox was pictured and that was what was shipped. I orded it about a week ago, and had it delivered to the local Sears store....that's when the story gets interesting.
To pick it up you scan your bar coded email at a kiosk (not a merchandise person in the area) and a stock clerk brings it to you. "But wait, I have a $40 coupon". You have to see so and so in the TV dept.
I go there and he was aware of the coupon, and said not to worry - I'd get my $40. They had an email from HQ saying they were working on the procedures of how to process the $40 coupons. He also said they didn't have any of the boxes in the store yet, this was the first on he had seen. He took copies of my order, coupon and promised to get it resolved and call me.
The unit was easy to install. The setup wizard worked quite well and the scan locked all of the OTA digital channels that my 52" Panasonic HDTV locks. The picture was an improvement over the analog picture on the 20-year old TV to which it is attached. There are no apparent artifacts. Just a good solid high quality picture.
It is an analog pass thru model. You have to set it up in the OSD menu once, then you can turn the TB100MG9 off to let the analog regain control.
One caution, you can delete unwanted channels. However, when you delete a channel, you delete ALL the channels in that broadcast stream. If you want to delete Ch 66.4, you wind up deleting 66.1, 66.2, 66.3 also.
For channel surfers, the TB100MG9 only takes a second or two to lock the next channel as you move up or down.
It has 1, 2, 4-hour automatic power down and an "always on" setting. When it is off, there is no heat coming from the box which is good since like it's earlier sibling it does not have any vent holes in the case.
Bob
Bob
post #13 of 119
4/28/08 at 4:06pm
Neither the Sears nor KMart site search engines brings up this item. Do you have a link?
post #14 of 119
4/28/08 at 4:19pm
- bdfox18doe
- CrackPot DTv Engnear
- offline
- 6,075 Posts. Joined 10/2000
It's reasons like this I no longer shop at Sears..("Sorry, Everyone Around's Really Stupid")
It's a shame tho, they have good stuff and an excellent selection, tho poor merchandising and even worse customer service.
post #15 of 119
4/28/08 at 4:32pm
Bob
Bob
I have a few questions please
1) Can you manually add a tv station or only Auto scan?
2) The analog passthru. Does the signal strength go down when you turn off the box? Or is it the same as before you had the G9
3)Does the box get hot while on? I understand you said while off it does not. Is the transformer in the box or on the electric plug cord?
4) It was $50 correct?
5) can you compare the EPG and display to other Cebes? Is the EPG a few days or just the next show?
6) Are you happy with it?
7) What antenna are you using?
8) Is the remote the same as the W9 original box? Are the buttons small and does it control the TV
Again thanks
post #16 of 119
4/29/08 at 2:11pm
post #17 of 119
4/29/08 at 6:02pm
I just got this box today from Kmart. I have to say there is small little vent holes on it. in the back and under the box. I think I have to upgrade my ant. I only get PBS on the dtv side. The anlog does breakdown but I use a vcr so that be the problem. So far I have not heard of no bad audio sounds let. I have a bose surrond sound system. The box only costed me 13.00 I was the first one who got it from kmart in the area I am in.
post #18 of 119
4/29/08 at 6:59pm
Could you answer the questions I asked BOB above? Or try?
post #19 of 119
4/29/08 at 7:13pm
Yes you can manualy add channels in but sub channels you can not manualy add in. Box does not feel hot to me. Like I said they did put in some vents there is a set on the back and there is a few small tiny holes that look like they was added after the box was made on the buttom. the cord cannot come off the box. The anlog does degrade but that might because I use a VCR with my box. It does not control the tv. the remote is the same i think. But box feels like it is built alot better then the one walmart sells.
post #20 of 119
4/29/08 at 7:26pm
Yes you can manually add channels in but sub channels you can not manualy add in
Can you expand on this? Lets lay you manually add channel 4.1 will the sub stations be included? EX: 4.2 4.3 4.4
When you add in main station are the sub stations included?
IF not how do you get the sub stations?
Are you happy with the quality?
Is it true you just turn off box for analog pass thru?
thanks
post #21 of 119
4/29/08 at 7:42pm
I do not know about adding the sub channels yet. All I get right now on the box is PBS. That is because I have to get a better ant tomorrow. I am happy so far with how PBS looks. The box goes into like a sleep mode when you go into the setup menu you turn on the analog channels. You have to use your tv remote while on the analog side to get off analog channels you have to hit the menu button for 3 seconds. If you have any questions I will try to answer them about this box
post #22 of 119
4/29/08 at 7:57pm
I am confused for analog
BOB said that you go to menu and tell the ox you want analog and then from that point forward you just turn off BOX for analog and use TV as normal and to get back to digital go to channel 3?
Is this wrong? IF so please give a step by step on how it works?
Can you set it up once and then just turn off box?
Everytime you want analog do you have to go into the Menu?
BTW look at TERK-55 for a great indoor antenna I am not sure you need indoor or outdoor
post #23 of 119
4/29/08 at 8:38pm
- dattier
- offline
What area is that, Ben?
You folks can see to the left where I'm located. Yesterday I went to the two nearest K-Marts and the two nearest Sears and not one of the four had a single CECB of any model by any manufacturer.
post #24 of 119
4/30/08 at 2:05am
I am from Jacksonville Fl. I need a indoor ant.
lexus to do analog pass though the steps are:
1. Push the setup button on the remote controll
2. In the setup menu you go to the channel submenu
3. You click on the Rf out
4. You select RF pass through and Yes.
5. The box goes into like a sleep mode and you use your tv remote to wacth analog tv
6. When your done wacthing analog you hold down the setup button on the remote for 3 seconds.
You have to do each step every single time.
post #25 of 119
4/30/08 at 6:10am
post #26 of 119
4/30/08 at 6:15am
I wonder why BoB said differen't
Could you check something for me.
Can you turn off box and see if you get analog passthru? Maybe with loss of signal? It might work right?
post #27 of 119
4/30/08 at 8:18am
- Malouff
- Away for Now
- offline
- 819 Posts. Joined 3/2008
It might be because one is using Composite inputs and the other is using RF.
As I understand it depends on how your T.V. Is Setup if you can set RF Passthu once and leave it.
Just using the RF can you can't leave the box in RF passthru to watch both Digital/Analog and must switch in the menu.
Using both RF and Composite you can leave the box in RF passthru and view analog and digital switching to AUX/Line In/etc., to view digital.
Originally Posted by Rammitinski
You just have to switch inputs on the TV with your remote between Auxiliary (Video 1, or whatever) and RF (the TV's tuner).
You will have to do a scan first with the TV's tuner so that it programs in all the analog channels. And you should probably leave the CECB tuner "on", because when they're off, the ones with pass-thru usually attenuate (weaken) the signal somewhat.
Originally Posted by Malouff
Looking at the User Guide it looks like "SETUP" is the button to switch the RF settings
It also says that channel 3 is the default channel.
Now here is a question how does this setup button cycle work?
Channel 3, Channel 4, RF PassThru
or just Channel 3 and RF PassThru?
Do you need to press "SETUP" for three seconds to switch from analog to digital or can you keep it on the RF PassThru and use both analog and digital changing to channel 3 to access Digital by default?
Originally Posted by Scooper
On the Philco box ( yes - I have one) - if you select RF Passthru - it literally does just that - it passes thru the RF signals. In this mode, you can power it off and get a strong signal through, but degraded in strength. However, it will NOT display on channel 3/4 when in this mode. Sorry guys - I wanted it to work like "power-off - RF passthrough, power on - you watch this box" too, but that's not the way this box works. THAT is why I've been saying you really need A/V inputs.
You CAN find an external modulator / switches to implement what you want.
post #28 of 119
4/30/08 at 10:20am
Ok I just went to the store and Bought a G9. My local Sears had it and they had about 6 to 8. No problem with coupon. He did have to swipe it 5 times though
Since I am not around the corner from my Aunt. It will be a week or so before I get over there. She in 83 and I have to hook it up for her as well as go get it from store. I don't mind that is what family is for, right?
Anyway I opened it up to read the instructions. I noticed the Remote has no volume controls? And it is small buttons
For analog passthru I read the instructions different.
after you go to menu and select Rf passthrough you watch tv as normal.
Now if you want to go back to digital you can do menu OR press and hold Setup button for 3 seconds to switch between channel 3 or 4.
No where does it say hold button for 3 seconds to get RF passthru.
Until i get this box hooked up. No way to know for sure. Maybe someone here can help?
post #29 of 119
4/30/08 at 10:47am
post #30 of 119
4/30/08 at 10:57am
- Malouff
- Away for Now
- offline
Yes after you select RF passthough you watch Analog TV as normal and as I understand it you can't access digital unless you are using RF and switch back or if using Composite change to the AUX/Line In/Etc.
Using the RF and wanting to switch back you can.
1. Press and Hold Setup button for 3 seconds.
I don't think you can see the menu in RF Passthru
You might just be correct with this one as it says the following
You also can switch between CH3 and CH4 by holding
[SETUP] down over 3 seconds.
It sounds stupid that you can't also use [SETUP] held down for three seconds to get RF PassThru.
Talk about being convenient for only RF users
Hopefully your Aunt has Composite.
However it also says the following
To view analog TV channels through the STB, the STB must be turned on.
It has been reported that this is not true, you can access Analog when powered off but degraded in strength
Personally a switch does sound easier to use for the elderly except for the fact that they have to get up and physically switch it.
Also lexus2108 what was the price at Sears?
Was it the $49.99 listed for Sears item# 05757778000
Sylvania DTV Digital-To-Analog Converter with a Magnavox picture.
Back to Forum: Coupon Eligible Converter Box (CECB)
- Magnavox TB-100MG9 availability
Currently, there are 1686 Active Users
(308 Members and 1378 Guests)
Recent Discussions
- › Anyone here using an Emotiva UMC-200? What are your thoughts? 3 seconds ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 37 seconds ago
- › Star Trek 2 1 minute ago
- › Is the End of Physical Media Inevitable? 1 minute ago
- › The Official HSU VTF-15H Thread 1 minute ago
- › Calling all Polkies:Official Polk thread 1 minute ago
- › Best cd/sacd player for $100? 2 minutes ago
- › Proposed outdoor setup - your advice needed 2 minutes ago
- › Official Samsung UNXXF7100 Owners Thread 2 minutes ago
- › Wireless bandwidth requirement for 24/96 streaming over DLNA 2 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › VIZIO 55 inch Class LED - M3D550KDE by indept
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
