Originally Posted by
dat1978
thanks so much to everybody for all the info on these boards. for christmas i bought the 46" panny 80U (costco version) for my new place. i downloaded the break in images and have run them on an SD card as well as watched some full screen movies (Planet Earth HD-DVD) for a total of almost 200 hours according to the timer in the service menu.
anyway, i've used some of the setting posted by various members and really love the picture clarity and quality of the set. however, while trying out all the different blu-ray and hd-dvds i have i've noticed that the blacks have a grey tint to them. its not noticeable when the screen is full of images which i figure is because the of the contrast between the bright images makes the black look darker. however, on screens that are predominately black you can see the grey and the blacks aren't deep. a good example is on HP: The order of the phoenix HD disk when the WB logo comes towards you in the beginning. another is in the beginning of the dark knight bluray, and also throughout the darker scenes of the movie.
so my question is, how dark should the black levels be? i've heard so much about how plasmas have better black levels which is why i chose it. should it be pitch black or is some lightness in the black level due to the technological limitation of plasma? will tweaking the service menu or getting it professionally calibrated help?
thanks for the input.
I know that nobody here dare use this but i do and I must say that for the majority of my viewing I like it better.
I lately have been using the 'Dark' black level setting w/ an increased brightness. This obviously makes the blacks more inky but also eliminates that sometimes faded background look and makes colors pop more. If you are unsatisfied w/ your black levels, it doesn't hurt to try it. Sometimes if you are watching a movie w/ lots and lots of dark/night scenes, you may want to revert back to light to avoid the slight crushing that can occur at this setting.
I currently use (w/ black level set to dark):
Cinema
pic: 54
bright: 56 - 75 (depending on what I'm watching, brighter if lot's of dark scenes)
color: 38-44 (depending on material/type of program - higher for nature shows)
tint: 0
sharp: 50
temp: warm
clr mgmt: usually off but occasionally on for nature shows and football games if the field looks extremely washed out
x.v.: auto
else: off
black level: DARK
Give it a shot and mess with the settings for various shows and see if you like it better. I would say I use this for 75%+ of what I watch. Let me know what you think!
